Old 14th March 2004, 12:22 PM   #1
promitheus's Avatar
Default Relay Volume Control for BLS
I just finished my PCB for a relay volume control.
This is only the relay board which only has the relays, resistors and driver circuits.
The Ralays here are the Takamisawa Relays at 12 Volts. The resistors are Welwyn low noise but very good priced.
There is one more board with the PIC Microprocesor and encoder on it which looks like a small poti. I will be posting that soon. I donīt have the encoder yet.
What is very practical is that you can stack the relay pcbs to get as many channels as you want.
One board is for a stereo signal or one balanced signal. If you want to balanced signal like I will be using for the Balanced Line Stage then you can use 2 PCBs one on top of the other.
You can even use more pcbs for a surround volume.
More information will come soon.
Old 14th March 2004, 12:39 PM   #2
promitheus's Avatar
This the Relay board.
I tonly has the Relays, volume resistors and the driver parts.
This is the whole board.
Old 14th March 2004, 12:41 PM   #3
promitheus's Avatar
This is a better pic, close up and sharper.
Old 14th March 2004, 12:42 PM   #4
promitheus's Avatar
Some pics of the unfinished boards
Old 14th March 2004, 12:43 PM   #5
promitheus's Avatar
These are the unfinished Control and PSU boards.
Old 14th March 2004, 04:13 PM   #6
sianturi's Avatar
How 'bout the schematics?
The Great Saiyaman
Siapa bertelinga hendaklah ia mendengar... (Mat 13:9)
Old 14th March 2004, 05:05 PM   #7
promitheus's Avatar
For the microprocesor control and info you can get from TIllīs website here:
http://home.tu-clausthal.de/~tpa/relais/index.html
Till was kind enough to give 2 PICs so I could start this project.
I really want to thank him for his help.
The relay part is a bit different from Tills or from Nelson Passīs.
It is a constant load attenuator. That means the load is always 5KOhms no matter what the setting.
I will find links and info on the subject.
Actualy you can find everything in this forum.
Old 14th March 2004, 05:08 PM   #8
promitheus's Avatar
this is the thread with info.
Constant impedance relay-resistor logarithmic attenuator
Old 15th March 2004, 11:01 AM   #9
Banned
Very pretty PCBs, i wish i had that pretty PCBs for my projects... Please report your findings with the corntroll, and keep in mind iīm still involved developing the firmware. Maybe you experience and ideas will help for further improvements on the code.
Old 15th March 2004, 11:07 AM   #10
promitheus's Avatar
Hi Till,
thanks for your nice words.
Without your help with the firmware my project would work in the first place. When I order some more boards I will give you some at cost price if you want.
Do you have done anything new with the firmware?
What I wanted to do is give the Volume control a display of some kind.
One idea is using 8 leds decoding the binary 8 bit code to decade.
Or a 7 segment led display.
Or the best but expensive a lcd display.
relay volume control cubezone Chip Amps 14 3rd May 2007 07:12 AM
relay volume control - POP! wayne325 Pass Labs 22 26th August 2006 01:58 AM
ADC for relay volume control? hegestratos Solid State 7 17th January 2005 11:39 PM
Remote relay volume control kit. harvardian Swap Meet 1168 15th September 2004 07:07 PM
Page generated in 0.10065 seconds (76.88% PHP - 23.12% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
