Old 14th March 2004, 10:19 AM   #1
akira is offline akira  France
Default [OT] Design a MOSFET heat load
Hi all,
Sorry for the slight off-topic post but I needed help from MOSFET masters.
I m building a Phase-change cooling for my computer. To test the cooling power I d like to try it on a heat load. (Not directly on the CPU). Therefore I d need a heat load that would be ajustable between 60 and 200W. I thought MOSFET would be a good try.
Could any of you, masters of the MOSFETS, draw me a quick shematic describing how I could do that ?
Thanks a lot,
Akira
Old 14th March 2004, 10:30 AM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Use a big power resistor and a suitable power supply.
Big power resistors are relatively cheap and a reliable controlled source of heat.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 14th March 2004, 05:23 PM   #3
The one and only
Nelson Pass's Avatar
I recommend the resistor approach, as it will work equally well
with AC and DC and is rugged and easy.
If you are using DC and you insist on Mosfets, just make a big
constant current source with Mosfets in parallel.
Making a current source is not a tough task, I suggest you
peruse the A75 or Zen articles ( www.passdiy.com ) where
there are some tutorials. Just remember that when you want
to get to 200W and are paralleling Mosfets, give each one its
own Gate and Source resistor. Measure the voltage across the
Source resistor(s) to determine the current, and set the DC on
the Gate(s) accordingly.
Old 14th March 2004, 09:08 PM   #4
Jaac is offline Jaac  Netherlands
Jaac's Avatar
Hi there see here Heatshink test In the past we did some heatshink tests. on the pic's you can see we used a big power supply 40V/70A. we ran ( ) some amps trough some resistors you then kan calc your power that is dissipated by your resistor.
sorry for the bad englisch
gr Jaac
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
problem with heat of MOSFET yanuarbob5150 Class D 8 9th February 2009 03:11 PM
Mounting Mosfet on Heat Sink ttan98 Pass Labs 11 14th April 2006 09:31 PM
transformer load on MOSFET??? AudioGeek Solid State 2 17th July 2004 12:32 AM
Heat Sink for Dummy Load mclagett Parts 7 27th May 2004 02:04 AM
[OT] Design a MOSFET heat Load akira Solid State 2 17th March 2004 06:36 AM
Page generated in 0.07347 seconds (72.00% PHP - 28.00% MySQL) with 10 queries
