Balanced connections on FW DIY AMPS - diyAudio
Old 4th January 2017, 02:57 PM   #1
Default Balanced connections on FW DIY AMPS
I am new to this hobby, maybe a year at most (never could have done it without this forum). Under my belt are 2 M2s, 2AJs, and a VFET DIY amp.
My system requires the use of an active digital crossover that requires a balanced connection. What I am using now is a cable that makes this conversion, however, I am not sure I am happy with this set up.
I am not knowledgeable enough to know if this is possible or how to even begin, but can I modify either of the amps that I have into a balanced connection amp? (obviously the AJs have this option). Specifically the vfet, it is my favorite, can it be made to have balanced connections or better yet both?
Please forgive me if this is a dumb and easily answered question. Thank you for your time in reading my thread.
Joe
Old 4th January 2017, 04:21 PM   #2
doolav is offline doolav  United Kingdom
Check this: Balanced XLR -> Unbalanced RCA Transformer..
Old 4th January 2017, 06:11 PM   #3
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
it is important how is made analog part of your xover - is it proper symmetrical/differential circuit , or is it just (usually is) slammed two SE stages , each working on one phase
if later is in question , there is hardly any benefit of using bal connection ......... just use pins 1 and 2 of XLR , feeding RCA downwards
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 5th January 2017, 06:58 AM   #4
I had used a BTL/Bidge style configuration on a F6 with great results, please check this posts:
The diyAudio Firstwatt F6
Old 5th January 2017, 02:08 PM   #5
Thanks all, I'll review and read these links. From the surface it does not look an easy thing to do... maybe not worth it.
FWIW, I am using an OPPO105D as a pre to the Digital XO which is a xillica-4080 that feeds the AMPS. One amp channel for each driver.
The goal is to remove any 60/120 Hz line hum as my speakers are super sensitive.
Joe
Old 5th January 2017, 04:56 PM   #6
Install a balanced to unbalanced transformer inside the Vfet amps. If your goal is unwanted noise and you have long cable runs to the amps you will want to run balanced naturally. The transformer will also isolate any ground loop potentials as an added bonus which will further reduce your noise floor.
Win-Win.
Converting all unbalanced connections to balanced dch53 Tubes / Valves 6 29th July 2015 09:03 AM
multiple amps to speaker connections henrylrjr Multi-Way 1 6th September 2013 05:12 PM
external connections for Chip Amps achristilaw Chip Amps 2 8th February 2005 09:27 AM
balanced connections jesserparker Solid State 1 14th March 2004 11:21 PM
About my amps mains connections JensRasmussen Solid State 26 9th October 2003 11:52 AM
Copyright ©1999-2017 diyAudio
