I am finally building a Pearl. (Got the parts almost 2 years ago. I am using the power supply schematic in the instructions. Transformers are Digikey TE70053, each with two 15VAC .5A secondaries in series. The trouble is that the supplies put out about 53 VDC unloaded, and exactly 50 VDC with a 1K ohm load (50 ma). Will this be too high for the regulators on the Pearl pcbs? Or will the load of the Pearls drag down the voltage further? Should I drop the voltage down further before the Pearl boards?
I will post pictures when this is finished. Thanks in advance for any help! Dave Kimble dave.kimble@gte.net |
#2 |
The one and only
Wayne says no.
#3 |
Thanks!
I am super cautious when it comes to the initial powering up of a project. I've failed numerous "smoke tests" in my life! Dave Kimble |
#4 |
The one and only
Amplifier builders and vampire hunters have two traits in
common: Patience and Fearlessness .
#5 | |
The series regulator can handle a bunch more disapation than this. Mine barely heats up the sink. I think the sonics are improved when running the input voltage up on a regulator like the one in the Pearl. The stored energy increases with the square of the voltage differential. A cap at 20 volts above the regulator stores 4 times the energy of one running at 10 volts above. George |
#6 |
just be sure to use silver solder too
#7 |
Yep! Silver solder was my first choice!
I am also using Arctic Silver II thermal compound on the regulator heatsinks, although it sounds like they don't really need it. I have used it on CPU heatsinks, noticeably increasing the heat conductance, but I have never heard of it used in audio. I imagine it would work well in power amps. Dave Kimble |
| Pearl phono with 24V battery supply | koli | Pass Labs | 1 | 9th August 2007 05:03 AM |
| Power supply for Pearl phono | mattjk | Pass Labs | 6 | 11th February 2005 08:25 PM |
| Pearl Phono power supply | Gregorio | Pass Labs | 1 | 13th October 2004 06:12 PM |
| Pearl enclosure and power supply? | Boban | Pass Labs | 20 | 27th February 2003 03:43 PM |
| Beginner questions about Pearl power supply | Saurav | Pass Labs | 3 | 26th September 2002 04:18 PM |
| Page generated in 0.09797 seconds (83.14% PHP - 16.86% MySQL) with 10 queries |
