diyAudio Moderator Emeritus
After reading Leach paper, I get impression of the importance of Re in differential stage. It is to advoid TIM (Differential overload), so Re should be about 100-300ohm attached to source/emitor of differential pair.
But looking at all the designs by Mr.Pass, it never uses Re at all. Starting from A40, ONO, to ZenV7. Does the issue of TIM is not having any relevance to good sounding power amp? All Mr. Pass designs are good sounding, but not having Re at all. |
#2 |
Few amplifiers use as much emitter degeneration as the Leach,
and some use none at all, as you have noticed. While a high value extends the linear region and improves overload protection, it also has drawbacks such as lowering the gain, so it is as with most things, a compromise. The Leach is a quite old design, using rather slow output devices, for instance. An amplifier with faster devices and otherwise designed for higher bandwidth may not need as much overload margin as the Leach, assuming the input is properly LP filtered. |
#3 |
The one and only
Re is not the only place where you can degenerate the signal,
although it has appeared in my designs at various times. More often than not, my circuits are simple and have so low an open loop already, that they don't need degeneration to lower the open loop gain. Like anything else, try it both ways and see what you like. |
#4 |
Maybe 2 stage designs (Pass) don't have as much gain "margin" so they can't use as much degeneration.
But 2 stages amps have certainly less TIM, due to the simplier circuit path Am I right? |
#5 | |
The one and only
TIM is too high. Real life measured signals in audio material, vinyl and CD, don't show the kinds of slew rates that would be postulated to overdrive the input stage (played at reasonable levels, of course). This stuff has been looked at by myself and Peter Walker, both published elsewhere, and supposedly for TIM to be a problem, it requires slew rates to exceed 1/10 the rating of the amplifier. As a practical matter, this means that an intelligently designed amp at 100 watts and 15 V/uS shouldn't have anything to fear. At the same time, there have been amps rated at 1,000 V/uS that didn't go anywhere, so even if it is a factor, it clearly isn't the only one. The same is true of THD. There have been a number of amps in the past that measured THD in a few parts per million that were poorly thought of. |
#6 |
" The Leach is a quite old design"
And the 300 ohm resistors are a very recent addition. "Personally I think the emphasis on TIM is too high. " I'm old. So old I own some of those black things they call 'LPs'. Some of those are even scratched. On a run-of-the-mill amplifier the scratches can seem to last forever, a broken-glass hall-of-mirrors effect. On the Leach the scratch is a short 'tic', and its done. On the run-of-the-mill amplifier the scratches are totally mixed in with the music. On the Leach the scratch reproduces up front in a different plane from the rest of the music. You have to hear this to totally understand. It may not be TIM that makes the run-of-the-mill amplifier sound so poor. It may not be low TIM that makes the Leach sound so much better. I hear the newest Leach boards sound much better. Maybe my 25+ year old ones will fail and give me an excuse to find out. |
#7 | |
Thanks Mr. Pass, for the explenation. What is really the sound of amplifier having TIM? Is this "Re eliminating" can be applied also in VAS? I see in A40, Mr. Pass do not use Re in the VAS transistor. If I want to eliminate Re in VAS transistor, assuming the Vbe is 0.65V, what is the voltage drop in the differential collector resistor? Should it be more than 0.65V or less than 0.65V? |
#8 |
The one and only
For every diff pair, there seems to be a sweet spot, true of the
Aleph P/ BSOZ and all others. If it sounds better, why worry about TIM? |
#9 |
One word of caution--if you intend to build a circuit that creates a balanced signal from a single ended input, you will find that putting too much resistance between the Sources/emitters/cathodes will interfere somewhat with the phase splitter aspect of a differential. Otherwise, have at it.
Grey |
#10 |
How? Please explain that.
Regards, Jam |
| amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? | siu sin man tho | Digital Source | 0 | 17th March 2004 12:31 PM |
| El Pipe-O is up at www.passdiy.com | Nelson Pass | Pass Labs | 81 | 6th March 2003 04:36 PM |
| PassDIY Gallery | Karen | Pass Labs | 10 | 2nd August 2002 06:53 PM |
| passdiy.com | Nelson Pass | Pass Labs | 38 | 18th April 2002 09:32 AM |
| passdiy.com | passdiy.com | Pass Labs | 9 | 23rd February 2002 02:13 PM |
| Page generated in 0.10920 seconds (80.61% PHP - 19.39% MySQL) with 11 queries |
