Passing Wires Through Panels - diyAudio
Old 21st December 2016, 12:06 AM   #1
Wayniac is offline Wayniac  United States
Wayniac's Avatar
Default Passing Wires Through Panels
I've read on this forum multiple times, that passing a single conductor through a metal panel is not recommended.
It has been posted, that a twisted pair passing through a metal panel is the preferred practice.
I'm curious, can someone please explain this to me? Thanks!
I laugh at your puny tubes.
Old 21st December 2016, 12:12 AM   #2
2 picoDumbs's Avatar
Probably depends more on what the function of the single wire is.
Wires are passing through holes all the time. Think about the rear panel of the amp
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 21st December 2016, 12:42 AM   #3
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
we just like to have some fetishes
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 21st December 2016, 01:40 AM   #4
rayma is offline rayma  United States
Currents flow in loops, so there has to be some route back to the source of the current.
If the way back isn't near the wire, then there's a large loop area that can result in noise problems.
Old 21st December 2016, 01:59 AM   #5
Wayniac's Avatar
Specifically, I'm building an F5 using diyAudio V3 PCBs. The wires I wish to pass through are the DC power and return. The wires will terminate on the F5 PCB about 1 cm after passing through the panel.
I plan on minimizing exposed wiring by running the both the AC and DC wiring in separate channels milled into the under side of the amplifier.
Attached is an image of my planned component lay out.
Sent from my iPhone using Tapatalk
Old 21st December 2016, 02:12 AM   #6
You don't need to run single wires through holes to achieve what you want here.
Even though that transformer looks nicely shielded, I think I would place the transformer right next to the front panel of the amp with caps in the middle of the amp case.
Old 21st December 2016, 02:34 AM   #7
Wayniac's Avatar
Are you suggesting I twist the three DC power leads for transition through the panel?
Regarding the transformer location, I'll take that under consideration.
Thanks for your help. This is my first build...
Old 21st December 2016, 02:40 AM   #8
Do you mean 2xDC and 0V twisted together?
Old 21st December 2016, 02:52 AM   #9
Wayniac's Avatar
Thanks for this explanation. Many of the F5 photos I see here have individual wires for the DC runs to the PCBs. Of course, they are direct runs not passing through any chassis panels.
Old 21st December 2016, 03:26 AM   #10
Wayniac's Avatar
Yes.
Deon Bearden passing Too Tall Multi-Way 6 15th February 2014 10:34 PM
Passing of a member (muizel) BrianDonegan The Lounge 3 15th May 2010 01:28 PM
£¸£´£µ no dc passing the opt VanguardVillage Tubes / Valves 1 17th January 2006 12:49 PM
Best caps for signal passing rtarbell Parts 16 4th December 2005 08:40 AM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 07:47 PM
Copyright ©1999-2017 diyAudio
