BOZ vs B1 - diyAudio
Old 19th December 2016, 06:02 PM   #1
fabrice63's Avatar
Default BOZ vs B1
Hi everyone,
I need your help to understand what is the difference between the 2 .
what i mean is this : what happens to the signal ( in my case +/- 1 v from the DAC ) , before it goes to the F6 amplifier .
what the signal looks like after being passed through them , in terms of volts , gain , db , etc ... i read many post , article , and i didn't find clear explanation for newbies like me .
Old 19th December 2016, 06:14 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
one has gain , other no
you can combine them , if you need low output impedance
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 19th December 2016, 06:44 PM   #3
fabrice63's Avatar
ok, but if one has no gain, what happens to the signal , if 1v goes into the B1 , what comes out ??
Old 19th December 2016, 07:18 PM   #4
2 picoDumbs's Avatar
B1 will do 1V in 1V out.
If you don't need added gain then B1 is probably the better choice, if you do need gain then B1 isn't gonna work for you.
I have both B1 and a modified BA3 in one case. I use either depending on how much gain I need.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 19th December 2016, 07:39 PM   #5
fabrice63's Avatar
ok, but if my 1v in , still 1 v out , what do the B1 , if voltage remains the same , freq will too , amp too , whats happens to the signal ??
something will happens , otherwise what is the B1 for ??
it look's like newbie words , because i am, Tank's ...
Old 19th December 2016, 08:08 PM   #6
Besides impedance matching, the theory is if you don't need gain to reach your normal listening levels, then less active and passive components in the signal path will allow more of the pure recording to reach the amplifier then out to the speaker.
B1 is mostly used as a separate volume control that can be hooked up to any power amp, instead of having to add a volume control to every amp you own.
Less is more if done correctly.
Hope that answers your question.
Old 19th December 2016, 11:38 PM   #7
Soundhappy's Avatar
Classic high-fidelity elements :
Audio Source |
DAC , CD-Player, Computer with audio card and many others...
Line preamplifier |
A) passive
Ok solution if Audio Source with high gain at his output
just volume resistor potentiometer or better switch, Light depended resistance ,
autoformer volume control all's with buffer ( signal is not make stronger= amplify)
Transistors are used to share at the output signal who are in harmony with power amplifier
give them impedance power amplifier need to play large frequency range bandwith from low 20Hz to high 22 KHz and more.
If impedance is not adapted by the buffer to the power amplifier music have "short" bass and high's frequency losses.
B) active
semiconductors are used to amplify boost small signal make them higher
gain level at the output for power amp input's
Power Amplifier |input impedance match to preamplifier , output impedance match to speakers
Speakers | impedance match to power amplifier output : 4,8,16 Ohm's
Idealy we don't need active preamplifiers or passive buffers because DAC or CD-player
source gain level and his impedance are perfectly adequate for power amplifier input....but in many cases that not happen.
Active preamplifiers and passive buffers bring flexibility to play with different audio sources and power amp's
of your choice and preserve recorded music integrity.
Best regards
File Type: jpg A2638811-29FC-4A48-AA65-D10F00743880.JPG (175.3 KB, 375 views)
class A amplifiers with full range speakers
sings like angels in heaven
Old 19th December 2016, 11:43 PM   #8
Zen Mod's Avatar
I'm choosing postamplifiers
Old 19th December 2016, 11:56 PM   #9
LBHajdu is offline LBHajdu  United States
The B1 is a Buffer (a source follower), which is to say it produces a lower impedance at the output. The Firstwatt F4 is the same maybe reading about it will help. Schiit Audio also has a product called Saga which as a tube buffer. Lower output impedance stops parasitic capacitance such is long runs of cable or amp inputs from sucking off all the top end because it allows more drive current, but no voltage gain.
Old 20th December 2016, 06:51 AM   #10
ElFishi is offline ElFishi  Europe
ElFishi's Avatar
My go:
Buffer means no gain (Uin = Uout) but lower impedance (Zin > Zout).
Impedance denotes the ratio of voltage over current and in real circuits it is always finite.
If the stage after the preamp draws lots of current from the preamp when fed with a voltage (i.e. it has low Zin) the output voltage of the preamp will sag. How much it will sag is expressed by Zout of the preamp. Low Zout means low sag.
Impedance of an inductor or a capacitor is dependent on frequency. For a capacitor its absolute amount goes down linearly with frequency and capacitance. That's why LBHajdu writes cable capacitance sucks off the top end.
Multichannel Mezmerize B1 or Pass B1 ORNJ Pass Labs 9 11th August 2015 12:04 AM
Pot > B1 > step up transformer > B1? sharpi31 Pass Labs 19 20th October 2013 01:45 PM
Mesmerize B1 vs Original Pass B1 - please guide me! KT Pass Labs 9 6th September 2012 05:57 PM
Boz RobPhill33 Pass Labs 3 13th January 2003 05:28 PM
BOZ ding Pass Labs 4 25th November 2001 10:52 PM
Copyright ©1999-2017 diyAudio
