F4 Beast Builders
F4 Beast Builders
Old 5th December 2016, 06:46 PM   #11
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Originally Posted by generg View Post
and keep in mind that I use the "old" Sony frontend, there is newer version in the Sony II thread with slightly changed resistors and possibly better sound as Nelson was told when he got some feedback from people.
Naah that was different application.
In my opinion since your choice is the same as mine it must be the best choice. Hahahaha
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 5th December 2016, 07:15 PM   #12
generg is offline generg  Germany
generg's Avatar
F4 Beast Builders
And I tell you I am deeply impressed by the clarity and finesse of sound!
So Nelson real XA25 must be heavenly!
and the First Wtt is......a really First Class PSS Idea
Old 5th December 2016, 07:19 PM   #13
needtubes is offline needtubes  United States
...so here comes my Hockey Puck Puzzle.....
This is similar to what I have modeled, except for the following:
1. No degeneration resistors anywhere
2. Different "coupling" of the driver to the outputs like in the UGS/UP which avoids capacitors in the signal path, but might make bias touchy
3. No cascode on the JFETs
4. IRF610/9610 MOSFET drivers instead of the Toshiba parts (too afraid to test with my precious Toshibas)
The model, for what its worth, looks fantastic. With luck, I will be able to find time to cobble this together some time in the next month...
Now, the important question for generg: How does it sound? Edit: you were four minutes earlier than me.
Old 5th December 2016, 07:26 PM   #14
Generg
Do you have any prototype pictures? Zen Mod is mostly interested in observing porn.
Old 5th December 2016, 08:59 PM   #15
generg's Avatar
F4 Beast Builders
I refuse to send porn through my devices.....:-))
I will have a look!
Old 6th December 2016, 04:52 AM   #16
nr12 is offline nr12  Germany
I will have a look!
There is a porn, errrr, private mode in all browsers.
Old 6th December 2016, 06:02 PM   #17
lhquam is offline lhquam  United States
In post #130 Pass XA25? I discussed bias circuits for the output fets. There is an LTSpice simulation comparing 3 bias circuits for an IXTN40P50P operating between 25C and 75C with 24V rail voltages, and 1.3A (approx) bias current.
  • Constant Voltage Bias
  • Thermistor Controlled Constant Current Bias
  • Opamp Servo Constant Current Bias
The plots show Vgs and Id for the FET vs. Temperature. As expected the bias current increases with temperature for the Constant Voltage circuit.
The Thermistor Controlled Constant Current circuit tracks very well with the "ideal" Constant Current Servo.
Old 6th December 2016, 07:07 PM   #18
I sssume that simulation is done with thermistor at exact same temperature as mosfet.
Generg's is mounted on heatsink.
Is it possible to simulate the effect of mounting the thermistor in different locations.
Old 6th December 2016, 08:19 PM   #19
generg's Avatar
F4 Beast Builders
Thank you lhquam! Very usefull to know that the Thermistor Controller System can do well. To show this in this way is so valuable.
Old 6th December 2016, 11:29 PM   #20
Sorry for my previous post. I am not sure now it got sent to this thread.
F4 Beast BuildersHide this!Advertise here!
Stereo F4 comparison to twinn F4 monoblocks Manolo47 Pass Labs 0 21st November 2016 01:25 PM
Orion Beast mbates14 Car Audio 0 20th March 2013 10:21 PM
A Bride for a Beast? Johnloudb Pass Labs 6 29th November 2009 12:10 AM
F4 Builders in Germany Flecko Pass Labs 0 25th February 2008 06:37 PM
The Beast... sklimek Tubes / Valves 5 29th June 2005 04:04 PM
