F4 Beast Builders
F4 Beast Builders
Old 13th March 2018, 05:39 PM   #1381
lhquam is offline lhquam  United States
Default FE bias sanity check
People (aka greedy boys) have spent a lot of effort to stabilize the front-end (FE) mosfet bias current. Here are actual measurements of an amplifier I have built with the topology shown below. As you can see, there is no servo (or thermistors) in the FE of that amplifier.
From a cold start I made three voltage measurements and a heatsink temperature measurement at 9 points in time, spanning just over one hour.
Across positive rail Rsen (0R27)
Across positive rail J313 source resistor (22R1)
Output offset voltage.
The OS and FE bias currents were computed from the voltages.
Conclusion: No need for a servo to stabilize the FE bias vs. temperature.
Old 13th March 2018, 05:51 PM   #1382
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F4 Beast Builders
agree with you 100%
I did what I did from several reasons ...... first we always are figuring how exactly Papa did it , further how to make it different
not necessary better (possible or not ) , but necessary not (much or at all ) worse than Papa's original
well , that I can say for my self for sure
long time past the point of must have new amp ......... never going to past the point of must have fun
(Italics written in Homer Simpson voice)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 13th March 2018, 08:18 PM   #1383
Ian Macmillan is offline Ian Macmillan
Agreed, did anyone previously disagree? This really is no different to the regular PL front end albeit with capacitor bypass, i.e. it has DC local feedback due to the MOSFET source resistors. The need for a servo, if there is one, would arise only if you wish to remove the MOSFET source resistor and the associated capacitor.
Old 13th March 2018, 09:09 PM   #1384
vitalstates is offline vitalstates  United Kingdom
vitalstates's Avatar
Originally Posted by Zen Mod View Post
agree with you 100%
so true
but never going past the point of understanding for me...it's still a learning process...but still fun...
so, sorry for the naive questions...I am aware that you guys have been at this thread for a long time, and also aware of the effort put in.....
ok creep mode over
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 13th March 2018, 09:51 PM   #1385
Zen Mod's Avatar
F4 Beast Builders
you had all legitimate questions
to be precise - all questions are legitimate ; only in case when asked by someone demanding spoonfed , they become questionable
Old 13th March 2018, 11:22 PM   #1386
flancfuster is offline flancfuster  Romania
Hi everyone,
I'm following this thread with great interest and I'm gathering parts to build the "beast". For now I have the hockey pucks and I'm looking for a transformer, but I don't know what voltage to choose for secondary. Any recommendation?
Lynn, in post #1290 you had positive results with stability of OS. The rails are 40V. Do you recommend to try that OS bias method? I'm thinking of mixing Sony VFET PII FE with OS from post #1290. Any thoughts?
Thanks.
"Without music, life would be a mistake." - Nietzsche
Old 15th March 2018, 02:42 AM   #1387
Ian:
Here is a topology without DC degeneration of the j313/K2013 MOSFETs. I found resistor parameters that work well.
File Type: jpg Ideal-ZD25-3-2nd-stage-cascode-noDCdegen.jpg (90.0 KB, 139 views)
Old 15th March 2018, 03:21 AM   #1388
Amendment: I have not found parameters that pass the ZM pulse test.
Old 15th March 2018, 06:50 AM   #1389
Zen Mod's Avatar
F4 Beast Builders
what is max. value [mA] you can take as passed?
Old 15th March 2018, 08:41 AM   #1390
Ian:
Interesting twist using an opto LED (U23) as a Ďdiodeí matching the voltage drop of the bias opto (U21) Iíve not tried this but I did do something similar using an LM385 voltage reference. In my case I used it just on the FE but I wasnít happy with the amount of servo gain, i.e. it didnít control the FE MOSFET current very tightly. Does your variant work better taking the sense from the output stage MOSFETs?
More importantly, does completely eliminating the degeneration resistors and associated capacitors in this way actually improve performance of the amplifier?
F4 Beast BuildersHide this!Advertise here!
Stereo F4 comparison to twinn F4 monoblocks Manolo47 Pass Labs 0 21st November 2016 01:25 PM
Orion Beast mbates14 Car Audio 0 20th March 2013 10:21 PM
A Bride for a Beast? Johnloudb Pass Labs 6 29th November 2009 12:10 AM
F4 Builders in Germany Flecko Pass Labs 0 25th February 2008 06:37 PM
The Beast... sklimek Tubes / Valves 5 29th June 2005 04:04 PM
