DEF Amp
DEF Amp
Old 5th August 2018, 08:11 PM   #331
claudio52 is offline claudio52  Italy
claudio52's Avatar
Location: Mediterranean Sea, near the Circe enchantress
DEF Amp
Hi chul, The resistance network illustrated by Mr Pass is a simple and elegant solution.
I hope this helps.
Old 5th August 2018, 09:48 PM   #332
lhquam is offline lhquam  United States
Here is a way to see the gm of the output stage and the input impedance. Look carefully at the expressions in the top two plots, the .measure commands in the .asc file, and the resulting log file output.
Old 5th August 2018, 10:42 PM   #333
Chul is offline Chul  South Korea
I hope this helps.
Attachment 695522
Thank you Claudio,
Now I see how the calculation. May I ask more questions?
Vdc at output is 0 not to use the capacitor. But you need to adjust the Iq to some value, say 1.5A, which is subject to other conditions like Vds. So these affect each other..? Are the -3.76 and -3.65 are fixed values that are determined before?
What if I just use output capacitor? Does this make it easier?
Thank you in advance.
Old 5th August 2018, 11:08 PM   #334
Originally Posted by Nelson Pass View Post
Of course you can always use a conventional bias circuit, just make sure
the bias polarity is in the direction you want.
Thank you for confirming that. I wonder what would the difference in sound with/without the 0.6ohm Source resistor in my 2SK82/IRFP9240 circuit. Maybe my ears can tell.. or can't.
In my country, we are having a record hot weather these days. This morning I checked the AC power voltage and it was 201 VAC(! air conditioning ?), not the nominal 220VAC. So if I use some regulated Vds adjustment to unregulated bridge-capacitor supply, would this affect the bias in worse direction?
Old 6th August 2018, 02:45 PM   #335
claudio52's Avatar
DEF Amp
Hi Chul, Vds and Id are initial project data. I chose +/-24V and 1.3A. With the two data have to measure the two Vgs. The test circuit is in posts #90 and #93. You have to wait at least 30 minutes for everything to stabilize. The two Vgs must be as close as possible. Before building the DEF, try to simulate it. It's not important which NJF you will use. This will allow you to understand that to reach 0Vout a precise resistors value is necessary. As shown by Antoinel it will be necessary to add a small trimmer to R3.
Imput impedance will be low. This will also be evident in the simulation. To increase it you can use the bootstrap capacitor and increase the -Vdc of the resistors.
Old 6th August 2018, 02:53 PM   #336
claudio52's Avatar
DEF Amp
Thank you, very very interesting
Old 6th August 2018, 05:46 PM   #337
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
DEF Amp
0.6 ohm Source resistor will make a difference, particularly if you tap
the speaker output at one Source pin vs the other. Off the SIT, you
typically see less 2nd harmonic, Off the P ch, more.
I personally find the undegenerated output more interesting sonically.
As to the power, regulated DC reference is best, as it leaves constant
DC value for Vds for the SIT, which is more sensitive than the P ch
Mosfet.
Old 7th August 2018, 06:22 AM   #338
Mosfet.
Indeed the undegenerated one sound better to me!
I took out the 0.6 ohm resistor and across the 100ohm resistor tested a CCS circuit of 10mA (simple DN2540 - 500ohm pot to adjust - 12V battery, not referenced to ground) this worked just OK and now I can adjust current, Vgs, and also the voltage across the SIT. I will add a simple 15V supply for the CCS and this way I can play with more SITs that are just sleeping in the box.. Thank you.
@ Claudio
Thank you for the explanation and now I see better. I am a kind of chicken to try without output capacitor. But in time I may be confident...
Old 7th August 2018, 09:11 AM   #339
I uploaded what I did here;
Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
Old 10th August 2018, 08:01 PM   #340
Antoinel is offline Antoinel  United States
DEF Amp
Default New DEF Schematic
The attached is a new DEF schematic. Some details are:
1. I used a fixed +/- 16 Vdc PSU. Idle drain current for each FET in DEF was 1 Amp.
2. DEF can use Vin[A] or Vin [B] or [Vin A] plus Vin[B] simultaneously. The line amp sourcing the two identical Vin[A/B] is a CD player's headphone output. It has plenty power drive.
3. The hypotheses therein circuit are that the BJTs do error correction, bootstrap and possibly introduce positive current feedback [PCF] inside DEF. If this hype is valid, the added complexity beyond that of the basic DEF by Mr. Pass [meaning no BJTs] maybe accepted as valuable.
4. This DEF embodies several operational variables. For example by using Vin[A] or Vin[B] or Vin[A+B] to name a few. May have a positive and/or perceptible effect on performance.
5. DEF sounded great [as an example] with the input signal simultaneously injected at the gates of both FETs [why not for a change?]; meaning {Vin [A+B]}. And the output capacitor [220uF] was also engaged at position 1 of the switch. This cap is believed to alter the gain of the BJT complex.
6. The shown BJTs are both Germanium. Delta Vgs of the FETs was ~0.75V. It is also called the [Vcb] for 2SB186. I felt this Vcb may be too low to allow for the proper operation of a typical Silicon BJT; like 2N3906.
Best
Anton
DEF AmpHide this!Advertise here!
Multicore CPUs & their desktop boards: Any risk to high def audio quality? oltos Digital Source 0 17th April 2014 07:12 PM
Def Tech Powerfield Supercube II Sub Amp john65b Swap Meet 3 15th May 2013 01:43 AM
Def Tech PF-10 amp lcq1 Subwoofers 1 29th March 2012 03:21 PM
