Pass XA25?
Pass XA25?
Old 17th November 2016, 06:51 PM   #21
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Originally Posted by needtubes View Post
distortion at 25W into 8-ohm was similar, but max power distortion into 2, 4-ohms was higher in my simulation.
That's why I think it's probably some sought of Source Follower Output.
Maybe it's push pull source follower combined with a healthy amount of single ended bias like the other XA amps but without the supersymmetry circuit.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 17th November 2016, 07:20 PM   #22
Originally Posted by Zen Mod View Post
clever cheapskate can always joggle with approach to and difference between balanced , symmetrical and differential .......
When I was a boy, I was bloody hopeless with Christmas Presents. Hahahaha
The suspense is killing me.
What do you think of the possibility of old school White cathode follower, could that be defined as single ended?
Old 17th November 2016, 11:24 PM   #23
Jon Ver Halen is offline Jon Ver Halen  United States
Default XA25
Single ended INPUT. The amp is push-pull
Jon Ver Halen
Lowther-America
Old 18th November 2016, 03:29 AM   #24
plasnu is offline plasnu  United States
From Xs manual: The original Aleph 0 from 1991 used an output stage which consisted of a push-pull Class A output stage operated in parallel with a high constant current output stage. The bias currents were high enough to operate to rated power in single-ended Class A, giving it a second harmonic signature, and as a push-pull topology at higher power levels.
Is this what you guys guess?
Old 18th November 2016, 04:30 AM   #25
Yes this is what I have been guessing, if not, then some more Papa genius.
Good chance it might be half of a regular XA.8 amp but biased higher than normal with a large share of single ended bias.
Old 18th November 2016, 04:35 AM   #26
Thank you very much Jon, can't wait to learn more about it.
When should we expect to see these for sale?
If push-pull are you able to confirm that it is a complementary pair of N and P channel mosfets at the output, or is it a quasi-complementary push-pull output stage?
Old 18th November 2016, 07:43 PM   #27
woody is offline woody
According to this it's single ended.
Pass Laboratories XA25
Old 18th November 2016, 08:32 PM   #28
Yes I've read that a dozen times.
The problem is single ended can mean quite a few different things.
I would put my faith in Jon Ver Halen since he has a very good relationship with Papa and actually sells Firstwatt products.
Old 18th November 2016, 08:39 PM   #29
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Pass XA25?
ZM knows Station
inputs are RCA , so there is no doubt
but , from rest of text ...... there are so many choices
SE or not , figures in A/8R , A/4R, A/AB/2R ....... not so many choices for OS
are there any complementary pucks ?
I tried to find complementaries for my thyristors , but nada ....... it seems I'm doomed on mosfets
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th November 2016, 09:12 PM   #30
ZM knows Station
There are P Channel Pucks but not true complements, having said that there is no such thing as true complementary p channel parts, and if papa intentionally creates asymmetry by adding single ended biasing in parallel, then probably no need to have complementary parts in the first place, just find the closest match with regards to current, transconductance and power rating and Bob's your uncle.
Some quasi complementary set up wouldn't be out of the question either.
Pass XA25?Hide this!Advertise here!
Pass Labs amp combination for Thiel speakers, need Mr Pass' advice ! And everyone... JulienG Pass Labs 82 6th July 2015 02:41 PM
Combine high pass tweeter with mids without low pass -Need help lessNoise Multi-Way 2 3rd August 2011 10:34 AM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
