Pass XA25?
Pass XA25?
Old 17th November 2016, 04:35 AM   #11
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Originally Posted by needtubes View Post
Perhaps a variation on the Aleph CCS?
Single ended may even mean that the circuit is just not a balanced circuit like the rest of the XA series.
I'm not willing to bet the house on it either way.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 17th November 2016, 05:21 AM   #12
needtubes is online now needtubes  United States
I did a quick mock-up in SPICE based on the description linked in the first post. While just a basic mu-follower, it simulates very well and matches the stated specs fairly well.
Old 17th November 2016, 05:57 AM   #13
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Pass XA25?
clever cheapskate can always joggle with approach to and difference between balanced , symmetrical and differential .......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th November 2016, 08:41 AM   #14
The only problem is, this seems to suggest a different front end,
"The simple front end circuit uses uses two pairs of NOS complementary Fets in common-source mode"
Old 17th November 2016, 08:49 AM   #15
woody is offline woody
If you look at the F1 it's described as a Ballenced Single ended so I assume the same term could be applied to the X series of amps. FIRST WATT F1
Old 17th November 2016, 08:58 AM   #16
The latest XA .8 series amps have complementary push pull output stages, although they do have a small amount of single ended bias.
Old 17th November 2016, 09:08 AM   #17
I wonder whether a Taylor Current Source (source follower output) might be used.
Would that be considered single ended? Or is that cheating.
Old 17th November 2016, 02:09 PM   #18
PSz. is offline PSz.  United States
PSz.'s Avatar
The artwork linked above doesn't show the two large power resistors mounted to the center heatsink on each side.
Old 17th November 2016, 02:38 PM   #19
"The simple front end circuit uses uses two pairs of NOS complementary in common-source mode"
Yep, I accounted for that. Used complementary JFETs in front end with IXYS mu-follower on output. Got results which were pretty close to the published specs. Power output matched into 2, 4, 8-ohms, distortion at 25W into 8-ohm was similar, but max power distortion into 2, 4-ohms was higher in my simulation.
Old 17th November 2016, 02:55 PM   #20
plasnu is offline plasnu  United States
Interesting!
Pass XA25?Hide this!Advertise here!
Pass Labs amp combination for Thiel speakers, need Mr Pass' advice ! And everyone... JulienG Pass Labs 82 6th July 2015 02:41 PM
Combine high pass tweeter with mids without low pass -Need help lessNoise Multi-Way 2 3rd August 2011 10:34 AM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
