Hi. .........This is the second BK AVP-1030 that has lost output with any source fed. The speaker trim outputs & the levels can be adjusted- I HAVE OUTPUT here. Anyone know the issue? Thanks. Resolved: Hi. After many hours, I found a fix for those of you with this B&K problem. Find U3 on the main board, carefully pry it out and clean the contacts--be gentle. You'll need to cut the strap over it to access it. Hope this helps someone out there.
