Seas A26 speaker?
Seas A26 speaker?
Old 19th September 2016, 07:03 PM   #11
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Seas A26 speaker?
SimonRA, Have you tried the boxes with the tweeters on the inside?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th September 2016, 08:04 PM   #12
simonra is offline simonra  United Kingdom
dave
Not until 10 minutes ago when i read your post... just swapped them over to see the difference but it's difficult to discern without being able to quickly flip between the two set-ups. What difference should I hear?
Old 19th September 2016, 08:07 PM   #13
Bigun is offline Bigun  Canada
Bigun's Avatar
Seas A26 speaker?
Is it April 1st already ?
Edit: oh, that 'inside' !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 20th September 2016, 12:42 AM   #14
hifibluedevil is offline hifibluedevil  United States
We did this Classic TL for this driver.
http://p10hifi.net/tlinespeakers/FAL...visited-WD.pdf
dave
Will this TL work with the classic ceramic magnet 25f-ew? The tweeters of a26 kit seems to be expensive compared to 27tdfc I wonder if I can use the 27tdfc in tl design as well with the 5uf filter cap.
Tia
Old 20th September 2016, 01:06 AM   #15
phivates is offline phivates  United States
Why not present a 21st century offset driver option for this driver?
Old 20th September 2016, 07:26 AM   #16
nicoch58 is offline nicoch58  Europe
nope that tw is big as cross lower ...
Old 20th September 2016, 09:28 PM   #17
Bangla H is offline Bangla H  Germany
Bangla H's Avatar
Default Morel UW1058
simonra
if you like use the not cheap (Neodym) Morel UW in a seeled 48-50liter
volume- very stable cabinet.
In same volume it will work too as a vented cabinet and plays a bit deeper.
The main reason for me to use closed is that it has less complication with
room frequency modulation and a bit juicy punch.
As Active Modul i use a IMG Stage Line D300 to drive that little Monster.
You can also test the Morel ore other bigger Speakers 15" 18"- Eminence
without a cabinet- the bass is room coupled and can play a bit lower its own
resonance, only my own tests and some experiments.
Old 21st September 2016, 12:54 AM   #18
What cap will be suitable for 25f-ew and 27tdfc tweeter combo in a A25 style aperiodic cabinet? These drivers were recommended replacements for the old Alnico versions in a Dynaco A25 which had a 5uf cap (and bunch of series resistors).
Old 21st September 2016, 01:41 AM   #19
frugal-phile(tm)
planet10's Avatar
Seas A26 speaker?
The string of Rs should alter the XO point as well as the level.
dave
Old 8th October 2016, 02:46 AM   #20
bk856er is offline bk856er  United States
bk856er's Avatar
Seas A26 speaker?
All A26 driver parts on hand. Brought home some decent 5x5' BB ply from MacBeath today. Hopefully making sawdust soon.
BK
Seas A26 speaker?Hide this!Advertise here!
SEAS A26 Speaker Kit HiFiHarry Multi-Way 62 28th December 2017 06:07 AM
Seas A26 aperiodic bracing & damping gerben00 Multi-Way 23 21st September 2016 02:43 PM
SEAS A26 crossover frequency nugat Multi-Way 5 7th June 2016 07:04 PM
SEAS A26 in oversize cabinet nugat Multi-Way 8 16th May 2016 04:04 PM
Before I order the parts for the Zaph Seas L18 / Seas 27TBFCG speaker mr_push_pull Multi-Way 17 17th August 2012 03:34 AM
