X-ccs bosoz need more gain - diyAudio
Old 5th September 2016, 06:56 PM   #1
tonimxp is offline tonimxp  Italy
Default X-ccs bosoz need more gain
Hi guy i just try to make some measures and i have just discovery that my x-ccs bosoz gain is only 2 or so (6db)
I compared its fft with my 6sn7 tube preamp ( i love his timbric),I'd likeit to amplify more (10db) and that had a predominance of second harmonic.
What are the elements that manage the gain ratio?
What can I do to manage the second harmonic distortion like I did with my F5 v2 turbo Power Amp?
To better interpret the values of the FFT 1Khz I also measured the sound card slot in 5,8db and 3,8db.
Later I performed the measurements on the X-ccs Bosoz.
My primary need, however, is trying to get more gain.
Please can you help me?
Thanks in advantage
Antonio
Old 5th September 2016, 07:58 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
as I said , for increasing gain - decrease value of both source resistors
regarding miniscule gain - triple check values of resistors you put on pcb
regarding invoking nonsymmetry in circ (invoking 2nd) , few tricks :
-different values of source resistors
-different values of drain resistors
-different values for NFB resistors (4K7/47K)
different meaning - not equal values left vs. right side
edit: quick analysis of voltage points and currents in your schematic is showing that 680/68R resistors are correct
what is a way of driving the preamp : bal in/bal out or ..... ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th September 2016, 08:41 PM   #3
Thanks ALEX i'm absolutly sure that all resistors value are ok.
Tests are made with in and out unbalanced mode.
I will try again to playing change resistors value.
Thanks.
Old 5th September 2016, 08:49 PM   #4
Zen Mod's Avatar
please confirm - with SE input , I hope you grounded neg. input ?
Old 5th September 2016, 09:20 PM   #5
yes according with schematic I have shorted -IN ( right side ) and -OUT ( left side ) to gnd.
Old 5th September 2016, 10:16 PM   #6
Zen Mod's Avatar
if you're keen of connecting output to gnd at all , then ground positive output , not negative
so , try it like this (using SE Input):
1. IN- grounded , none output grounded , use whichever OUT you want as SE hot
2. IN- grounded , OUT+ grounded , use OUT- as SE hot
choose which way you like more , and inform us what is gain in both cases
..... for now , only worse thing you didn't tried , is grounding all inputs and all outputs
Old 6th September 2016, 12:26 PM   #7
Hi the picture show :
Righ channel= IN- grounded , OUT+ grounded , used OUT- as SE hot
Left channel= IN- grounded , OUT - grounded , used OUT+ as SE hot
In both cases, if not short-circuit the pole consideration not used to exit (out + or -out) depends on the case mentioned above, the exit used accordingly becomes slightly more low.
I tried with 1,957 Vin and 4,242 Vout so the gain is 2.16.
Tried also by taking the + and - poles simultaneously same result gain.
Old 6th September 2016, 02:41 PM   #8
Tried r5 68//27 and no more gain
Tried short r16 4,7k and gain up only from 2,16 to 2,96
tried r17 47k//47k and gain down from 2,16 to 1,95
I can not figure out how to get more gain in this preamplifier!
Old 6th September 2016, 03:14 PM   #9
I think i have to replace r17 with one more value for more gain i think 470k, what do you think?
Any advice is welcome,thanks.
Antonio
Old 6th September 2016, 05:36 PM   #10
Zen Mod's Avatar
yes , you can try that , for test
you're using 5K volume on output ?
gain measured without any other load on output ?
BoSoZ with CCS -- need sugestion... sianturi Pass Labs 28 5th January 2010 01:15 PM
The ultimate CCS-X-BOSOZ Magura Pass Labs 76 4th September 2005 06:16 PM
Questions about a CCS-X-BOSOZ sbear Pass Labs 20 14th June 2005 03:16 AM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 01:55 AM
Copyright 1999-2017 diyAudio
