New ACA Build Low Power and Noise - diyAudio
Old 4th September 2016, 04:28 AM   #1
Default New ACA Build Low Power and Noise
I just built the ACA kit and using the switching supplies the power is only about a watt and the noise is 26mV on the scope. I tried the amp with my linear regulated supply and the noise is 12mV and the power is 6 watts. I let the amp burn in for 30 minutes and I set Q1 to 10V. Has any one else had this problem? Thanks
Old 4th September 2016, 10:27 AM   #2
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Iq in ballpark ?
is PSU voltage steady ?
just use other switching supply
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 4th September 2016, 12:40 PM   #3
xrk971 is offline xrk971  United States
xrk971's Avatar
Add 33mF (or 22mF) 0.47Rx4 33mF CRC in between your SMPS and amp should knock it way down (if SMPS doesn't choke on turn on in-rush). Precharge the caps first with 10R power resistor between SMPS and first cap. EThen use manual switch to enable full current after a minute.
If you want to know it down even more to 1mV level add a split core 0.56mH and and another 33mF cap for CRCLC.
Old 4th September 2016, 06:52 PM   #4
The amplifier works great from a linear power supply, there is no voltage sag on the switching supply. The inrush current is not a factor. The model of the power supply is: PPP014S. Has anyone else had a problem like this with this supply?
Old 4th September 2016, 07:39 PM   #5
Zen Mod's Avatar
dilemma is simple to solve - use other switcher supply
take it as black box , (which probably is, anyway) , it's either good or not
Help with ACA build cccochran Pass Labs 3 4th August 2014 10:43 PM
Ultra Low Noise and Low Power Consumption OCXO ULNOCXO Vendor's Bazaar 21 6th July 2014 10:39 PM
What is the ideal low-noise heater power for high-power output tubes? cyclecamper Tubes / Valves 37 18th January 2013 08:45 AM
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 14th September 2010 12:39 AM
Want to measure V on the scope: should I buy a new one or build a low noise preamp? Bricolo Parts 43 1st November 2005 09:41 AM
Copyright 1999-2017 diyAudio
