Old 5th March 2004, 09:20 AM   #1
JEKYLL is offline JEKYLL  France
Default Which thermistor for 230V AC line?
For a 230V AC line do I need to use a CL60 thermistor (5 amp max), a CL 110 (3.2 amp max), or a CL 120 (1.7 amp max)?
In fact my question is: if I use a CL 60 on my Aleph 3 with a 230V AC line the resistance of the CL 60 will be 1 or more ohms permanently (according to datasheet), is it a problem? What will be the voltage drop on the transformer primary?
Old 5th March 2004, 06:11 PM   #2
Refer to this thread.
CL-60 Inrush Current Limiter
Thomas
Old 6th March 2004, 07:30 AM   #3
Ok, but what about the drop voltage of the thermistor?
Under 5 amps the resistance of the CL60 is 0.18 ohm, but with an Aleph 3 and a 230V AC line the thermistor will work at approximatively 1 amp. So the CL60 resistance won't be less than 1 ohm. Is it acceptable?
Old 6th March 2004, 05:34 PM   #4
The one and only
Nelson Pass's Avatar
Yes, it works fine.
Old 6th March 2004, 09:04 PM   #5
Thank you.
Thermistor help luvtheoldschool Parts 5 4th February 2008 12:56 PM
help with ntc thermistor jarthel Parts 4 1st October 2006 04:57 PM
Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers Eva Swap Meet 1 28th July 2005 03:00 PM
thermistor larryg Solid State 15 21st October 2004 03:40 PM
Thermistor Location awhiteguy Parts 12 15th November 2002 08:42 AM
Page generated in 0.06620 seconds (78.30% PHP - 21.70% MySQL) with 10 queries
