Gyuri's Pass SONY VFET2 build.
Old 13th September 2017, 04:44 PM   #121
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Originally Posted by Gyuri View Post
It sings for more than three hours now.
I'm a happy man, with two Sony VFET amp.
Excellent news bravo Gyuri !
class A amplifiers with full range speakers
sings like angels in heaven
Old 13th September 2017, 05:34 PM   #122
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Thank you guys,
But wait a minute, none of them completely ready yet.
They are sing, it is good.
There much chassis work must have to be done.
Bridged mode wasn't tried yet.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 14th September 2017, 07:41 AM   #123
Gyuri's Avatar
Most impressive properties of Sony VFET:
First of all, it has a damned good sound, of course.
Second, there is no noise!
No hiss, no buzz at all, even if I put my ears on the loudspeaker.
This is the quietest one of all I've ever built.
You can not say quietest, it is not the proper expression.
There isn't any noise at all.
Tremendous.
Old 14th September 2017, 09:05 AM   #124
Gyuri's Avatar
I have a question about bridged mode.
As you can see it from picture above, (sorry for unusual bad quality, I will make better ones.) there are four bridge rectifiers and four cap banks for the two channels.
It means, there are no common ground reference for two independent amp, other than ground of inputs.
One of my solutions for this in similar cases, an external copper rod between negative speaker terminals.
Perhaps it would be better if I put it internally, between ground points of the two PCBs.
Any thoughts?
Old 14th September 2017, 10:44 AM   #125
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
copper rod is good enough , if speaker wire coming to negative connector is fat enough
regarding bridging - you want to simply bridge them ( feeding balanced signal etc.) or you want to make them truly differential ?
in case of later - you need pulling both R4s from ground and connect their ends together (in series)
of course , observing DC offset tendencies is a must
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 14th September 2017, 12:18 PM   #126
Gyuri's Avatar
Hi ZM,
Thank you for your answers, and questions as well!
Must have to say, I was thinking on first case only.
Most part of my system is true balanced, so I was thinking on first case only.
What could be the benefits of fully differential layout you suggested?
Can I use it in this way as a stereo amp?
Or can I use it in differential mode, and can I revert it by a switch connected in mids of R4s and ground?
Suspect in this case it isn't enough simply switch on, must be setting it from DC viewpoint.
Old 14th September 2017, 12:44 PM   #127
Zen Mod's Avatar
-What could be the benefits of fully differential layout you suggested?
-Or can I use it in differential mode, and can I revert it by a switch connected in mids of R4s and ground?....................
-Suspect in this case it isn't enough simply switch on, must be setting it from DC viewpoint.
-benefits - same as comparing usual mumbojumbo balanced vs. SUSY (differential error correction)
-yes , switch will do
-dunno - I didn't tried exact amp in vivo so I can't tell - so you need to check is there any DC offset wandering when switching from one mode to other
naturally - switching while amp is off , just in case
Old 14th September 2017, 12:50 PM   #128
Gyuri's Avatar
Thanks again, I think I will go on differential way, but first only simply balanced.
We must have the opportunity for development.
Old 14th September 2017, 01:17 PM   #129
zman01 is online now zman01  Bangladesh
Second one is up and running!
Congratulations! Double fun...!
Old 14th September 2017, 02:10 PM   #130
Gyuri's Avatar
Yeah, it was a real fun!
Gyuri's Pass SONY VFET2 build.Hide this!Advertise here!
PCBPCBs for Nelson Pass‘ CSX1 SONY VFET amplifier permaneder Group Buys 428 27th May 2018 02:25 PM
GB Pass SONY VFET Version 2 - AL Boards by Tea-Bag Tea-Bag Group Buys 112 22nd May 2018 01:38 AM
FS: Nelson Pass "VFET2" Front End PCBs luvdunhill Swap Meet 35 26th June 2017 09:21 AM
What is the difference in VFET1 and VFET2 sound? anilva Pass Labs 6 29th July 2015 12:21 AM
I'm going to build a Pass XOno. Gyuri Pass Labs 131 5th January 2014 11:07 AM
