Thinking About Building an F6 - diyAudio
Old 9th August 2016, 11:20 AM   #1
Default Thinking About Building an F6
Hi All,
Recently built an Aleph J (with considerable help for 6L6) and love it - it is very relaxed sounding amp that pairs well with my Zu Omen II speakers. I can listen to it for hours without any listening fatigue.
I am thinking about converting it to an F6 and would like to hear from anyone that has built both and see if they think it is a worthy exercise (basically, how does the F6 sonically compare to the Aleph J). Is the F6 a little more detailed than the AJ? I find the AJ to be a very mellow sounding amp. Again, I love the AJ, this is just scratching the itch to play with solder.
Alternatively, I have matched mosfets for an F5 laying around, so I could build one of those - I built one with 6L6 a couple of years ago but got rid of it because it was not a good match for the speakers I had at the time (it actually may work well with the Zus).
I built the AJ using the deluxe 4U jack of all chassis and power supply PCB from the store - so basically I would just be swapping amp boards.
Any thoughts/comments are greatly appreciated!
Thanks,
Matt
Old 9th August 2016, 12:04 PM   #2
wdecho is offline wdecho  United States
I built an Aleph 30 and swapped the boards to build an F6. I have horns and there was a difference in sound between the two amps. With my speakers I would prefer to have the Aleph 30 or J. I would strongly suggest building a complete new amp instead of just swapping boards. The Aleph J is that good. The F6 might produce a sound you like better with your speakers but if I were you I would advise keeping the Aleph J also. With 2 complete amps you can then swap boards on the one you like the least further down the road.
Old 9th August 2016, 12:14 PM   #3
Oh, I wouldn't get rid of the AJ amp boards - If I don't like the F6, I would just swap the boards back to the AJ. I just don't know if I want to spend $200 on F6 parts just to find out I don't like it.
Old 9th August 2016, 02:19 PM   #4
riksu is online now riksu  Finland
I tested F5 and F6 with my Zu omens and i like F6 much more.
Old 9th August 2016, 02:21 PM   #5
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
F6 will cost you more than $200 to build. It's $120 just for the boards and Jensen transfos. JFETs another $50 from the store?
other parts...?
Anyway, you need to read all the 6moons.com articles on the F series of amps they reviewed. You have the A-J, so then just use your imagination to interpret their descriptions. In the end, you'll want to build it just to hear what the hell they are talking about.
I build, therefore I am.
Old 9th August 2016, 02:39 PM   #6
plasnu is offline plasnu  United States
Old 9th August 2016, 02:47 PM   #7
qwertyl is offline qwertyl  United Kingdom
So far I only built F4 and Aleph J, but in my experience the differences between Nelson's amps are quite subtle. Usually what makes huge difference is speakers and/or sources.
I have just connected my Aleph J to an old Technics SL-1200 via Pearl 2 and it is entirely different world comparing to my digital setup...
Old 9th August 2016, 02:59 PM   #8
vdi_nenna's Avatar
I do have a 15w mini-aleph and it sounds very different than the F6 mosfets and F6 jfet. Mini-A is soft and not harsh sounding. The mini-A has mosfets front-end. I'm willing to bet the Aleph-J sounds a bit sharper than a mosfets front-end Aleph. So I think the F6 will sound closer to a F6. It's just my speculation. The output mosfets could have an impact as well. Fairchild vs IRF, etc, etc...
I'd build the Aleph-J (I have the boards Aleph-JX), but I have too many amps and too many more amps to build. Problems problems!
Vince
Old 9th August 2016, 03:17 PM   #9
gadut is offline gadut  Indonesia
gadut's Avatar
nahhh, everyone who posted in this thread must have built more than 1 Papa amp clone. Sooner OP will follow
one is never enough, so why only focus on F6? there are other hot stuff right now such as M2 or SIT
Old 9th August 2016, 03:36 PM   #10
Originally Posted by gadut View Post
one is never enough
Couldn't agree with you more :-)
Just building BA-3 while tweaking my Pearl 2 and waiting for Sony VFET kit...
Thinking of building SB12.3 sirrus1 Multi-Way 6 27th July 2014 09:16 PM
Thinking of building a set of speakers. srogue Multi-Way 1 4th September 2012 12:01 PM
Thinking about building some SR71s TinTurtle Multi-Way 1 18th October 2011 12:39 AM
thinking of building 7 way loudspeaker MisterTwister Multi-Way 31 29th June 2010 06:34 AM
thinking about building my first cabinet spc18 Full Range 1 10th July 2007 02:44 AM
Copyright 1999-2017 diyAudio
