ZEN vs. high capacitance diy speaker cable?
Old 2nd March 2004, 07:25 PM   #1
Vix is offline Vix  Yugoslavia
Vix's Avatar
Default ZEN vs. high capacitance diy speaker cable?
Hi there
As I am building the Zen amp, and waiting for a pair of Fostex 206e to be delivered, I also though about the speaker cable to be used with this configuration. Just yesterday I bought 6m (3+3) gray ribbon cable. However, this cable is said to have a rather high capacitance, and some amps may oscillate. Check out this:
http://www.tnt-audio.com/clinica/flatter_e.html
Anyone tried this with Zen? Comments?
Thanks,
Vix
Old 2nd March 2004, 07:49 PM   #2
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
As I understand it; Class A amplifiers are quite immune to reactive loads
Mads K
Old 3rd March 2004, 02:35 AM   #3
jam is offline jam  United States
jam's Avatar
Not so.
Old 3rd March 2004, 09:10 AM   #4
Mad_K's Avatar
I was thinking about the Zen/Aleph amps vs speaker cables, but it came out wrong. Sorry Jam
Mads K
Old 3rd March 2004, 09:31 PM   #5
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I haven't run across a case of Zen instability, due to the
extremely low feedback and relatively high output impedance.
As to whether the Zen is ideally suited to any particular cable
or vice versa is open to debate.
Old 3rd March 2004, 09:47 PM   #6
blank527 is offline blank527  Netherlands
Send a message via MSN to blank527
I'm an owner of an (not tweaked) aleph 60, and using diyCat5
speakercables.
I found some instability (hum)in my aleph so i'm currently using a zobel network with it.
They are connected to very badly 6 ohm speakers though. (next upgrade)
The strange (for me dissapointing) thing, was connecting these cables to an Hiraga amp, 20Watt version.
There was no instability (no hum) without zobel network. (also other speakers)
I found it strange, as hiraga uses (I think) more feedback, less bias current.
However the power supply has much more (overkill) capacitance, so maybe this is the cause.
Maybe the other cause is the speakers. (sensitivity)
Any explanations?
Remco Blankesteijn.
Old 4th March 2004, 07:26 PM   #7
The one and only
That's interesting. I assume that if you are running the input
single-ended you are also using the shorting jumper 1-3.
What cables andf length are you using?
Old 4th March 2004, 09:40 PM   #8
Vix's Avatar
It would be interesting to investigate this matter a bit further. It is a pity to build a good class A amplifier such as ZEN or Aleph, try to minimize sound quality loss with a good cable, but in fact do just the opposite. I know some folks freakin' about the choice of cables. As for me, I know they are not the most important part.(cables) However, I don't want the 'cable" to be the 'bottleneck' of the audio chain. As far I can see, high capacitance cable such is this ribbon risks doing just that. It will be nice to determine when the "improved"start doing more harm than good....
Viktor
Old 4th March 2004, 11:31 PM   #9
jam's Avatar
Mad K,
To me, Mr.Pass (our Zen Master) wrote the definitive text on speaker cable interaction.
http://passlabs.com/pdf/spkrcabl.pdf
It certainly opened my eyes, when I read it years ago, if you have not read it, you should.
Jam
ZEN vs. high capacitance diy speaker cable?Hide this!Advertise here!
Speaker Cable Capacitance and Amplfier Stability JCLNV Everything Else 17 24th December 2007 02:49 PM
Amp4 Mod Round-up Ė Input wire, power caps and high capacitance speaker cable Peteruk Class D 10 4th April 2007 06:12 PM
Charlize and high capacitance speaker cables fergs1 Class D 3 20th October 2006 10:26 PM
Zobel for high capacitance cable kiang Multi-Way 0 11th July 2005 09:52 AM
High capacitance speaker cables kiang Multi-Way 1 10th July 2005 08:41 PM
Copyright ©1999-2017 diyAudio
