What's wrong with the kiss,boy ?
Old 3rd June 2018, 08:24 AM   #491
DIYspaceW is offline DIYspaceW  Slovenia
Guys I managed to configre the cmoq-4 for 1:4 autoformer test and it sounds wonderful! Cinemag propably send me a phase reversed sample so the colors in datasheet dont match the transformer!
No problem!
Old 3rd June 2018, 08:29 AM   #492
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
glad you solved that
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th June 2018, 02:41 AM   #493
Anchan is offline Anchan  United States
What would be the disadvantage of using a 10k:10k autoformer rather than a 600:600?
Wouldn't the 10k input allow us to skip the jfets on the input?
Old 15th June 2018, 08:22 AM   #494
Zen Mod's Avatar
most probably adding too much to Rout
think about Rdc of windings ...... even if there isn't simple adding of Rdc in Rout figure , there still is substantial consequeance
Old 16th June 2018, 12:26 AM   #495
That makes sense, especially as a utility preamp, you don't want to high of an Rout.
I should have clarified- I am thinking of using this into a hiZ input, such as the Salas 6V6 buffer to get just a little bit of a boost.
Old 16th June 2018, 06:21 AM   #496
Zen Mod's Avatar
if you already have transformers at hand , fun is there ....... no need to wait
Old 7th August 2018, 12:18 PM   #497
sarathssca is offline sarathssca  India
can we use below audio transformer iron preamp:
(LM-NP-1001-B1L - Audio Transformer, 600 ohm, 600 ohm, Through Hole, LM-NP-1000 Series)
http://in.element14.com/bourns/lm-np...1-1/dp/1929741
its power level is given as "- 45.0 to + 3.0 dBm"
not much clear with its current or voltage ratings.. can use this for preamp for 6db gain..?
Old 7th August 2018, 01:14 PM   #498
Zen Mod's Avatar
I suspect it is not of quality to be on par with rest of concept
however - it's cheap enough , just try it
Old 7th August 2018, 01:47 PM   #499
Could you please tell what parameters to look for selecting a transformer for voltage gain in preamp.. from the iron pre it seems to be a 600ohm:600hom.. ie. 1:1 turn ratio (can we look for a 1:2 turn ratio for gain more than 6db).. what other parameters do we need to look for
Old 7th August 2018, 02:20 PM   #500
Zen Mod's Avatar
it needs to be linear ...... not just on paper , as many of these small and cheap thingies are
connected as autoformer , 1:1 is becoming 1+1 , having 2V/V gain , which is 6db
if you take 1:2 , it is becoming 1+2 , giving 3V/V gain , which is 9.5db
there is waste number of possible xformers ....... if you take 600CT:600CT , that's practically 4 windings of 150R (nominally) ......
you can use that one as 1:1+1+1 , resulting in 1+3 , having gain of 4V/V , which is 12db
and that's where I think you need to stop with gain , because Rout of entire shebang is really going up
What's wrong with the kiss,boy ?Hide this!Advertise here!
KISS the Ultimate Amplifier Elso Kwak Solid State 54 16th November 2008 11:51 AM
KISS my Subwoofer seekingwisdom Subwoofers 14 21st September 2004 06:40 AM
