Developing a Regulated Dual Rail Power Supply For FirstWatt Amps
Old 14th May 2016, 01:47 AM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
device which is responsible for Jules
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 14th May 2016, 02:45 AM   #12
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
I got output impedance down to 23mOhms by a very simple tweak.
I think I am more than satisfied with that.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 14th May 2016, 02:46 AM   #13
I'll post circuit later.
The battery in the laptop is about to go dead
Old 14th May 2016, 03:12 AM   #14
biju55 is offline biju55  India
biju55's Avatar
The circuit which you posted only for one channel ?. OR need to add more out put devices for stereo set up ?.
Old 14th May 2016, 03:37 AM   #15
All will be revealed.
You could run two channels off it, but I plan to do dual mono or semi dual mono.
Old 14th May 2016, 07:23 AM   #16
Given that most people are usually satisfied by a CRC supply I'm starting to think that the highest priority here is ripple reduction, followed by decent output impedance, with regulation being at the bottom of the priority list. So I'll also do a straight Capacitance multiplier supply as well, which has the advantage of an even smaller voltage drop.
Just thinking out loud.
I'll post up all the potential circuits
Old 14th May 2016, 08:48 AM   #17
woody is offline woody
What about a cap multiplier with a mosfet but adding a battery in the 3 to 6v range in series with the gate . This way you could have the voltage on the gate about 3 volts higher than the drain voltage so you wouldn't lose but a volt or so in the mosfet.
Old 14th May 2016, 09:38 AM   #18
I'll try it.
Old 14th May 2016, 10:44 AM   #19
Zen Mod's Avatar
you need bloody reservoir cap on output
build it , then listen with and without
then choose
Old 14th May 2016, 11:17 AM   #20
then choose
I have held off from doing that because you get a rising impedance response with decreasing frequency ie higher impedance in bass region as opposed to flat impedance.
If I add a reservoir cap it's gonna be 200,000uF to reduce this effect. Do you think there will be any problem with such a large capacitor on output?
I'm quite happy adding more bipolar transinstors if require.
Burning Capacitance Multiplier 1
Hahahaha
Developing a Regulated Dual Rail Power Supply For FirstWatt AmpsHide this!Advertise here!
Efficient dual rail DC power supply for car audio tfboy Power Supplies 3 10th May 2016 05:59 PM
Dual rail supply help surfstu Power Supplies 1 10th May 2016 03:16 AM
Can't Tell if Power Supply is Dual Rail Sh00pus Power Supplies 3 29th April 2013 12:21 AM
Need a 2W Bipolar DC - DC Converter circuit to make a dual rail power supply elmura Power Supplies 2 27th August 2012 08:30 AM
Building a dual rail battery power supply? pjpoes Parts 4 22nd January 2007 08:10 PM
