Old 27th February 2004, 12:21 PM   #1
tomecz is offline tomecz  Poland
Default aleph 3 and 89efficiency loudspeakers
hallo,
starting my first post with a quastion, not good. But maybe someone will responce.
I am in front of beginning my clone of 1st Aleph 3. I have dicided to clone this one, becouse it seems to be not so difficult.
I have read this amplifer may require some higher efficiency loudspeakers, >90db. If someone could tell me, if my VA Hadyn with 88,89db will be "prperly" driven by aleph 3?
thanks in advance
Old 27th February 2004, 03:30 PM   #2
MikeW is offline MikeW  United States
MikeW's Avatar
Default How loud
It all depends on how loud you want to play it.
MikeW
Old 27th February 2004, 05:45 PM   #3
Asen is offline Asen  Bulgaria
Send a message via MSN to Asen
I've been using 89-90dB Odin loudspeakers powered by a 10W SE JLH amp quite successfully for a while. They played loud enough. It depends on how big your listening room is, too. The difference between 10W and 30W is not that big in reality. At least not 3 times louder.
Old 27th February 2004, 06:36 PM   #4
The one and only
Nelson Pass's Avatar
Actually it is, but it isn't perceived that way. From your
description I imagine an Aleph 3 would do the job.
Old 27th February 2004, 10:50 PM   #5
Definitely would do the job. I myself am planning of building an Aleph 30. I have all the parts but I can’t find the time to put them together. And yes, I was talking about the subjective perception of the difference between 10 and 30W.
Old 28th February 2004, 05:49 AM   #6
thank for all your reply
i must admit, i was thinking, that my question is not only the "loudness of the music" problem. I do not hear music very loud usually. My room is 13 square meters large. I thougt that low efficiency lodsppeakers and aleph 3 may provide me with some inproper quality of sound.
so thanks one more time.
will report progress of the work
Old 28th February 2004, 09:45 AM   #7
Send a message via MSN to blank527
A friend of mine has a Hiraga amp with 20watt per channel.
They play loud with an efficiency of 88db!
(Remember with an aleph 30 you have 60watts for stereo.)
Remco Blankesteijn
Old 28th February 2004, 09:03 PM   #8
The one and only
As with sex, it isn't necessarily size that counts most. I have
heard small wattage amps do a better job of controlling a
loudspeaker and otherwise sound better, but I have also
heard the reverse. Assuming that you are not clipping the
amp, potential power relates to quality, but not always in a
predictable way.
Old 28th February 2004, 09:33 PM   #9
13 square meters is a small room (assuming this is the
floor plan) and 88/89db is not remotely low efficiency
(82db to 84dB I would describe as low) in my book 89dB
is medium/high ( 86dB/87dB being medium).
sreten.
Loudspeakers Gary Hubbard Multi-Way 4 19th July 2009 04:00 PM
Loudspeakers 101 Moondog55 Multi-Way 8 15th June 2008 02:24 PM
Loudspeakers Tiberius Parts 1 9th September 2004 03:02 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.09832 seconds (78.41% PHP - 21.59% MySQL) with 10 queries
