50w Single-Ended BAF2015 Schade Enabled
Old 5th August 2018, 06:21 PM   #611
dmy is offline dmy  United States
Originally Posted by analog_sa View Post
Do you have a capacitor in parallel to the switch?
No I did not put a cap there. I should try that. Thanks
Old 6th August 2018, 07:22 PM   #612
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Originally Posted by dmy View Post
....I do not have low output Z preamps all other pres are in the 1k - 1.5k range.
I did not bother to try them I am afraid the result would be similar.
I need a capable preamp.....
What preamp do you use to drive the Schade?
@ Dmy
Life is easy if between tube preamp and Schade 50W You install jfet's impedance buffer.
Every preamp output ~ 1.5K with the buffer together become 25 Ohm and give excellent frequency response from DC to ~ 200KHz.
It's single-ended 50 watt's and 20 dB of gain from IXYS mosfet
so no need for lot of more gain from preamp if good quality audio source
DAC or CD player ( no gadget : tablet's , smartphone etc. ).
Input transformers sound performance of Jensen and Cinemag is highly recommended or similar ( better ?)
Worse input transormers roll off low and high frequency and bring more distorsion to the music.
Do Your input transformers specyfications datasheet are garantie OK for an audio power amplifier ??
Schematic source : First Watt
Best regards
File Type: jpg 606E2B51-A390-4782-A2A0-2E6F7A90BE21.JPG (76.2 KB, 143 views)
File Type: jpg 60B38049-3252-4D08-85FA-2530EA4C7FE6.JPG (563.5 KB, 136 views)
class A amplifiers with full range speakers
sings like angels in heaven
Old 6th August 2018, 09:33 PM   #613
I used this input transformer in a DAC before, it is not the transformer that roll off the freq.
The circuit you provided below, can the DC be kept at 0v all the time? It does not employ cap to block DC any DC at the output will saturate the input transformer though.
Old 6th August 2018, 09:55 PM   #614
Soundhappy's Avatar
Matched 2SK170 | 2SJ74 pairs with Ids ~ 8.2 mA is ideal
but trimmer do the job if not perfect match and you get 0V DC all the time, +- 12V buffer PSU is regulated, stabilized
Old 6th August 2018, 10:18 PM   #615
Soundhappy's Avatar
More informations about impedance buffer | passive preamlifier is in Papa article :
http://www.firstwatt.com/pdf/prod_b1_man.pdf
B1 Rev.1 output impedance = 50 Ohm so Schade amp can go -3 dB 100 kHz at high frequency.
This version is build with 4 pcs. of 2SK170 BL grade and have 10 uF electochemical capacitors at the output.
Old 6th August 2018, 11:20 PM   #616
Thank you, Soundhappy. I will keep this in mind. The DIY audio store is currently out of the transistors
Old 6th August 2018, 11:47 PM   #617
Soundhappy's Avatar
This is verified genuine Toshiba seller , write him message about jfet's Idss=8.2 mA matched pairs.
Genuine Toshiba 2SK170BL/2SJ74BL high transconductance JFET complimentary pair | eBay
Perfect for the buffer no worry if little mismatch after all trimmer help to get 0V DC.
or this one Punkydawgs shop with tighty matched pairs but at higher price
Toshiba 2SJ74 + 2SK170 LAB MATCHED QUAD to 0.03mA AND 4mV (7ma range) | eBay
Greetings
Old 7th August 2018, 10:21 PM   #618
Will look into building the buffer. Thanks.
50w Single-Ended BAF2015 Schade EnabledHide this!Advertise here!
Single tube, Single ended, 20W, impossible? dannydanger Tubes / Valves 39 1st June 2017 08:18 PM
Single High power Mosfet for big Single Ended Amp ? Ado Solid State 20 25th February 2016 03:32 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
