what should i change on zen1 (original one) if i want to drive 4 ohm speakers...yes i know...paralel amp, but i dont want that...
thanks
too much is just enough |
#2 |
i`m no pro, just trying to help.
you could try lowering the rail voltage or increasing the tran`s current handling. with a lower load, i guess the only problem you will face would be a lack of current. |
#3 |
yaeh, but simplier for me will be like that: change Rx from xx to yy, and so on....
hvala (thanks)
#4 | |
#5 |
There should be a .66 volt across a .33 ohm R1. This sets the bias at 2 amps.
Change the value of R1 to a lower value. A .22 ohm will give 3 amp bias. Two .33 ohm in parrallel .165 ohm will be 4 amp bias. This will make the amp run hotter. Have plenty on heatsinking.
MikeW |
#6 | |
| Ohms? | ddoyle | Multi-Way | 6 | 3rd February 2009 03:38 AM |
| ISOBARIC 16 ohms load powered by 8 ohms Amp | eddi0 | Subwoofers | 24 | 21st October 2006 03:29 PM |
| Speakers: 8 ohms vs. 16 ohms | KT | Multi-Way | 2 | 14th April 2006 05:06 PM |
| 4 ohms vs 8 ohms | carieux22 | Everything Else | 5 | 16th July 2005 12:53 AM |
| where to buy 16 ohms l-pad | ger56 | Multi-Way | 0 | 11th October 2004 11:11 PM |
| Page generated in 0.08458 seconds (76.32% PHP - 23.68% MySQL) with 10 queries |
