B1 has died
B1 has died
Old 8th April 2016, 12:40 PM   #1
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Default B1 has died
How odd, my B1 has died, both channels at the same time.
To recollect, this build uses the PSU (SALAS Shunt Reg) from the DCB1 but uses a clone of the original B1 for the buffer.
It was working flawlessly and had been for several years.
I've just completed a Pearl 2 project which works perfectly directly driving my Aleph 4 - so no problems there.
I decided to add the B1 as a volume control and it's died.
I've tried the original CD source and the B1 is definitely the culprit.
I just can't believe that it's coincidence that the B1 has been killed by the Pearl 2.
This post isn't about "What is wrong", it's more about "Why"
Old 8th April 2016, 01:45 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
B1 has died
If you know what happened I'm sure you also can figure out why. It's harder the other way around.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 14 pcb's in interest so far.
Old 8th April 2016, 02:08 PM   #3
Everything is AC coupled so it just doesn't make any sense.
Old 8th April 2016, 03:01 PM   #4
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
B1 has died Send a message via Yahoo to vdi_nenna
Do you know if it's the DCB1 PS or the B1 circuit?
I build, therefore I am.
Old 8th April 2016, 04:33 PM   #5
peranders's Avatar
B1 has died
So why did it break? Have you done any fault tracing?
Old 8th April 2016, 04:35 PM   #6
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
B1 has died
Also, pics.
Gravity - Making the G since 13.7 billion B.C.
Old 8th April 2016, 05:21 PM   #7
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 has died
It's quite possible to blow the Gates with a spike.
Old 8th April 2016, 06:26 PM   #8
peranders's Avatar
B1 has died
Just for reference, a mosfet will be instantly destroyed of you apply 28 V gate voltage. For JFET's I have no personal experience to destroy.
The reason why I know about mosfets is that datasheets only say max ± 20 V but when do I break the fet and what kind of failures do I get? More than 26 V = no mercy.
Old 8th April 2016, 06:31 PM   #9
Dennis Hui is offline Dennis Hui  Canada
Yeah, and at least one member has encountered a large turn-on thump:
http://www.diyaudio.com/forums/pass-...ml#post2828745
Perhaps the OP can try measuring and see if that might be an issue.
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 9th April 2016, 03:06 PM   #10
I haven't had the opportunity yet to see where the problem might be.
B1 has diedHide this!Advertise here!
Multichannel Mezmerize B1 or Pass B1 ORNJ Pass Labs 9 11th August 2015 12:04 AM
Amp died?. Fool122 Car Audio 6 21st May 2014 05:51 PM
Mesmerize B1 vs Original Pass B1 - please guide me! KT Pass Labs 9 6th September 2012 05:57 PM
My Rotel just died hybridfiat Solid State 4 1st August 2008 01:33 AM
Need help--powered sub just died mouse Subwoofers 3 29th October 2003 02:18 PM
Copyright ©1999-2017 diyAudio
