search for "mosfet mist" here on DIYA , explanation by Papa
however , it's related strictly to P polarity , 9240 ........ so whatever brand of mosfets you buy - that's it
as far I remember - member h_a was having matched mosfets
edit: as far as I'm concerned , you'll definitely sleep better , knowing that you have WE wire in amp
and nothing else will be better
Pass DIY Addict
Joined 2000
I would recommend buying some equipment and matching your own. I started 15 years ago and just wanted my parts. About a dozen amps later, things would have been better for me from the beginning if I had just purchased some equipment when I first started. A decent power supply and a relatively good meter can be had for about $150. Then, just buy 30-40 mosfets to match your own and sell the rest.
For matching, follow my example.
I had to do one test before I do anything in my amplifiers. Is that to compare to another Aleph-X amp. I did so yesterday. And now I’m 100% sure that wat I heard on this second amplifier was wat I had 2-yers ago with my amplifiers. This heard not only me but 3 more persons. They all missed the midrange bloom. An they said that my amplifier is sounding very clinical in comparison.
So I have called my friend that was doing the modification on my amplifiers to check the schematics, measurements again. So hi will do so.
I hoop he will find anything so my beloved amplifiers will be sing again.
