Please help diagnose bad oscillation - diyAudio
Old 5th February 2016, 12:17 AM   #1
Default Please help diagnose bad oscillation
Ive built a low power aleph m of sorts without the active ac current source. using it as a gain stage. when powered up on +/- 45 volt rails it oscillates immediately at @ 1-1.2MHz. Anyone have any ideas what would cause this? please refer to the circuit pictured. using 9610's and 610's for the mosfets. Im using a connex smps power supply but had the same osillation when powered from a filtered transformer.
File Type: png Screen Shot 2016-02-04 at 8.15.29 PM.png (36.0 KB, 234 views)
Old 5th February 2016, 12:20 AM   #2
The one and only
Nelson Pass's Avatar
Could be Zener, could be high voltages on Jfets.
Old 5th February 2016, 12:24 AM   #3
no jfets in the circuit, bjt for the current source and mosfets for everything else. I would like to say a BIG thank you Mr. Pass for taking the time to reply to my question though! can you please give me more insight as to what i should look for? i would say Im a novice still with just enough knowledge to get in trouble, lol.
Old 5th February 2016, 12:29 AM   #4
are you saying the zener biasing up the current source for the LTP could be causing it? i place a cap across it but it didnt seem to change anything...
Old 5th February 2016, 12:51 AM   #5
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
cap across feedback resistor , increase gate stopper resistors , include blocking caps as originally in Aleph series (1nF in two positions)
look at attached for reference
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th February 2016, 12:57 AM   #6
i can say that when i tried a cap across the feedback resistor it raised the oscillation frequency to @6MHz
Old 5th February 2016, 01:01 AM   #7
i see the A30 link, I dont have what amounts to Q4 in the A30 circuit so do i still need 1nf in that position for stability? Zen Mod are you saying to use like 100 ohm gate resistors throughout?
Old 5th February 2016, 03:40 AM   #8
The Dastardly Dad of Three
What value cap did you try ?
Also, separately, in ref to Nelson's original suggestion - ditch the protection zeners at the input stage and see if that helps.
Old 5th February 2016, 05:22 AM   #9
palstanturhin's Avatar
If original circuit uses IRFP240 and now you have IRF610, change gate resistors immediately.
You may need to go as high as 2kohm...
Gradually, until oscillation stops.
Old 5th February 2016, 08:00 AM   #10
Zen Mod's Avatar
yup, increase value for gate stoppers
Bad capacitors. Bad design or bad caps? Hayden Parts 9 10th December 2014 06:38 AM
Help Diagnose my old amp. RedneckHotTub Car Audio 12 9th January 2014 12:42 PM
Please help me diagnose a Hypex problem mrimaging Class D 3 20th July 2013 09:28 PM
How to diagnose an old receiver? EvilYoda Solid State 5 1st June 2011 11:18 PM
Please help diagnose preamp problem gary h Tubes / Valves 9 3rd February 2007 10:57 PM
Copyright 1999-2017 diyAudio
