Super Triode Connected Aleph CCS Zen Amp - diyAudio
Old 3rd February 2016, 05:22 AM   #1
FYC is offline FYC  Hong Kong
Default Super Triode Connected Aleph CCS Zen Amp
Hi All
I am thinking about building an experimental amplifier employing a Super Triode Connection (STC) with a Zen amp + Aleph CCS. The STC was discussed rather in detailed in some Japanese audio website and also in TubeCAD. Employing the concept laid out in TubeCAD around mid 2015, I combined a Zen Amp (with Aleph CCS) and draw up the schematics. The working point that I selected was based on the components available in my parts inventory. I would like to ask the help from the forum to see if there are obvious miss in the thought before attempting to build one. Thanks.
Old 3rd February 2016, 08:10 AM   #2
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
maybe because still didn't get my morning coffee , but I can't see how's that going to work
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 3rd February 2016, 12:27 PM   #3
Zen Mod, you hit the right spot. I do not understand this also, hence I call it an experimental build. Nevertheless the claims made by the concept are so attractive that I am willing to spend the effort to experiment.
According to the claims, the triode is NOT part of the gain stage, but an active feedback element. With this Super Triode Connection (STC), you get the sound characteristics of the triode but the power of the main amplifier. So in my case, I can get a E88CC (or 6DJ8) sound-like power amplifier. This is very interesting.
I basically share the concepts shown in TubeCAD
Single-Ended Amplifiers & Super-Triodes and so on in building the schematics. Also, there is even a commercial offering using a gainclone with a tube:
Nixiekits.eu Finest quality Nixie clock and tube kits made in Germany
Old 3rd February 2016, 12:44 PM   #4
Upon cursory inspection, this looks more like a hybrid than a super-triode.
Old 3rd February 2016, 12:53 PM   #5
Hi Mike
I would argue that since the plate of the E88CC is also connected to the drain (output) of the lower MOSFET, hence this is not a typical hybrid type gain stage connection. In AC terms, the plate of the triode get signals from the amp's output as feedback.
Old 3rd February 2016, 01:05 PM   #6
Whatever you say, FYC. Seems like you've got it all figured out.
Append:
On second look, I'll buy it. Build away
Old 3rd February 2016, 01:27 PM   #7
Zen Mod's Avatar
it could be supertriode amp , if you didn't omit entire biasing circuit for lower mosfet
this way , all you could get is poof! in speaker
Old 3rd February 2016, 07:11 PM   #8
indra1 is offline indra1  Indonesia
Why? I believe FYC took the schematic from art_zv2.pdf. I think some of us would need a bit more explanation. Is it because he used 47k instead of 4k7? But I just can't figure that as valid cause for a poof!
Old 3rd February 2016, 07:17 PM   #9
Zen Mod's Avatar
as Mr. Broski said cleverly:
Wait a minute, John; what happens if the triode's cathode voltage isn't high enough to turn on the MOSFET; or too high, so the MOSFET over conducts and melts?
The answer is we need an auto-bias circuit to set the MOSFET's idle current flow, such as the one shown below.
and then he put this picture :
so , find that part on page , read and think
Old 3rd February 2016, 08:25 PM   #10
The one and only
Nelson Pass's Avatar
I see the logic of it - the Mosfet is driven by a Triode Cathode follower, and
negative feedback is provided by connecting the output (Mosfet Drain) to
the Plate and working the Triode characteristic of the tube.
FS: PCB(Aleph-x, aleph p1.7, zen v9,x-ccs-bosoz etc) seve Swap Meet 15 31st January 2016 05:31 AM
Ring of two CCS for differential triode amp - stability? ray_moth Tubes / Valves 15 6th August 2015 07:10 PM
Triode or ultraliner connected ? lduarte1973 Tubes / Valves 15 1st August 2013 11:31 AM
LM317 CCS Zen Style amp van garderen Pass Labs 8 12th March 2007 02:44 PM
6AU6WA triode connected as a line amp? grhughes Tubes / Valves 13 10th October 2006 01:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
