Looking for amp project similar to Aleph3 but more power - diyAudio
Old 3rd February 2016, 02:14 AM   #1
Dukja is offline Dukja  United States
Default Looking for amp project similar to Aleph3 but more power
I haven't DIY for 3 years since I totally recap my Aleph3. It is still working great with my Hifiman HE-6 headphone. But recently I got to try some speakers: Sierra-1 and a coming pair of New Philharmonitor. These speaker needs at least 40W @ 8 ohm and I didn't want to push Aleph 3 too hard on those speakers.
I like their sound pushed by Aleph 3 at low volume. The Aleph is directly connected to Audio-GD DAC-19 and I use Foobar2k to adjust volume. With 24-bit depth, I can use about -20dB without losing dynamic range.
I am thinking several routes to get higher quality watt with a budget ~$1k:
* get some Threshold amp and recap/update it
* build some mono Aleph 3 or 5 or Aleph-X (seems to be too ambitious) with too source on pcb and support here.
I really like to get some good quality watt (80~100W/Ch) but the 400W consumption/ch is really scary to me (and my pocket for AC). Is there some amp project that may deliver some nice initial 40W or so in class A and then transit to AB smoothly without losing the magic of Aleph 3?
Thanks a lot for the suggestion and ideas.
Old 3rd February 2016, 02:35 AM   #2
koja is offline koja  Canada
for Aleph-like sound I guess you are looking at a bigger Aleph running at higher rail voltages with maybe matched 2SJ313s at the front (as the newest "update" by Papa).
Alternatively you can consider bridged F4s running off of a balanced preamp of your choice (pumpkin, BA-3 FE, tube-based Impasse, Juma's LSK); these would be made as monoblocks. this is all classA and we are talking large heat dissipation.
F5 amp and its higher power derivatives can transition into high bias AB but this amp stands for detailed and not for Aleph-like sound so it can only be paired with suitable speakers which are a bit recessed by nature and not forward sounding or with a sparkly top end.
if size/heat/$$s are a concern, for your application actually a chip amp, an LM3886 based GC may be the best answer. or you can go straight after an AB amp like P3A or AX-11 and such. many choices...
Old 3rd February 2016, 03:08 AM   #3
Thanks for lots of suggestion. I am pretty rusty on all the amp derivatives that you mention. I read some about bridged Aleph 3 which has 60W @ 8ohm. I guess the bridged F4 will be the same.
My Audio-GD Phoenix is fully balanced preamp/headphone amp and the Ref-7 DAC is a fully balanced DAC. So monoblocks of DIY Aleph 3 or Aleph X may make sense for me. Does any of these projects have better documentation and support (PCB, etc) here?
F5 sounds interesting. Unfortunately, for these 2ch monitor, the recess of mid-range of these monitors is my biggest enemy. Is it a good fit?
As for chip amp, I am afraid my indulged ears may not agree with them. If is quite hard for me to get a pair of agreeable speakers after listening to well tuned HD800 or HE-6 systems (at least to me.)...
Old 3rd February 2016, 03:19 AM   #4
soundhappy's Avatar
My suggestion are :
more power = less natural sound [ too much transistors inside ]
the same power amplifier with more efficient speakers = much louder
and transparent sound [ only few transistors ]
speaker big magnets push the sound for free non additional electricity costs.
Was from CAS 2015 Mr Pass write article about amp watt / speaker dB / room space.
Thanks Papa
File Type: png 29AC5FDA-6DDE-47A7-8482-24A2685694E4.PNG (109.7 KB, 266 views)
class A amplifiers with full range speakers
sings like angels in heaven
Old 3rd February 2016, 03:30 AM   #5
Hay, thanks a lot for the table. Unfortunately, my speaker is 85dB and for some louder music session (Movie soundtrack or symphony) enjoyment 100W is right in the ball park. Or maybe I will cut down my enjoyment to 1/2 when I realize how big and expensive those heat sink costs.
I like high efficiency idea, but that is probably going to derail this thread. I'll research more on that later.
Old 3rd February 2016, 03:33 AM   #6
BA-3 with 30-32 volt rails, should give over 40-50 watts class A or there abouts. Otherwise Balanced BA-3 mono blocks, may be possible to double that.
I always thought a pair of Aleph 2 mono blocks would be sweet.
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 3rd February 2016, 04:35 AM   #7
soundhappy's Avatar
...I'll research more on that later.
Any chance to test your Aleph 3 with 95 dB / 98 dB speakers in local Audiophile Room Shop ?
Some times we don't know well treasure amp we have
File Type: jpg EA9F4772-106E-4941-9243-4514F1FD907F.JPG (63.8 KB, 252 views)
File Type: jpg E217B257-9D13-4583-B4C8-35E93031F34D.JPG (162.3 KB, 251 views)
Old 3rd February 2016, 04:36 AM   #8
2 picoDumbs's Avatar
Bablefish J
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 3rd February 2016, 01:19 PM   #9
Oh yes, I am using Aleph 3 almost everyday with my Hifiman HE-6 headphone with sensitivity of 76dB @ 50ohm. It works wonderfully. That was the main purpose for me to get Aleph 3 in the first place. Speaker setup is the second though.
Old 3rd February 2016, 01:48 PM   #10
Originally Posted by 2 picoDumbs View Post
Bablefish J
This is new to ignorant me. I'll try to spend some time looking into it. Thanks!
Looking for a new project. Anything similar to the Schiit Lyr? alfa147x Headphone Systems 19 7th May 2013 04:28 AM
Aleph3 DC Turbo Project n3szd Pass Labs 48 16th April 2013 03:09 AM
Similar at this speaker....do you know any diy project? 823 Multi-Way 2 21st June 2012 03:15 AM
Aleph3 dumping factor and power JacekPlacek Pass Labs 8 5th July 2004 07:13 AM
2.2mH inductor in Aleph3 Power supply vsr123 Pass Labs 10 9th April 2003 02:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
