Pass B-3 preamp build (sort of) - diyAudio
Old 29th January 2016, 04:19 PM   #1
Default Pass B-3 preamp build (sort of)
Ok. I am going to start off by saying that I have felt very much like an idiot the last couple of weeks while staring at my boards dreaming of sound...
About a year ago, I decided to build the F5 and the B-3 preamp. I bought the boards and stuffed most everything very quickly. Then life took over and I got sidetracked.
Well, a couple of weeks ago I finished my B-3 board and the Super Regulator board. I have the suggested Antek power supply. I would like to assemble these parts together in an old Radio Shack integrated amplifier case which I gutted if that is ok. It has the power switch, power cord, volume pot, and rca inputs intact.
The problem is that when I sat down to wire all of this together I realized that I have absolutely no idea what I am doing. I have replaced capacitors before and stuffed a few boards but my knowledge of electronics is beginner at best.
Is it possible to use this case with the parts that are already there? Or will it not work at all? All of the wires on the torodial transformer scared the hell out of me. Which ones go to the power switch or power cord?
I am going to try to tackle this again this weekend. And then maybe onto the F5 in a few weeks...
Any help would be appreciated.
Old 29th January 2016, 04:26 PM   #2
Read this:
The BA-3 as preamp build guide
Then this:
An illustrated guide to building an F5
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 29th January 2016, 07:09 PM   #3
I have read over that a few times. I will revisit and see if it makes more sense today.
Old 29th January 2016, 10:29 PM   #4
Well, it looks just like the transformer that 6l6 used. Is it Antek? If correct for BA-3 pre, primaries are the red and black wires. They go to switch, as 6l6 photos clearly show. Blue and greens are secondaries. Use continuity test with multimeter to determine the correct pairing. They go to rectifier/ power supply. Pictures show this clearly.
Wiring from power supply to board lightly more complicated but clearly dedicated.
Russellc
Old 29th January 2016, 11:47 PM   #5
2 picoDumbs's Avatar
The red and the black wires are the primaries.
The blue and the green wires are the secondaries.
That's all I have time for at the moment.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 30th January 2016, 12:05 AM   #6
KevinHeem's Avatar
Tackle the F5 first, it's an easier build when using everything availible from the diyAudio store.
Old 30th January 2016, 02:59 AM   #7
This seems to work for me.
https://www.youtube.com/watch?v=Yl6s6DGapug
Old 30th January 2016, 03:53 AM   #8
Russellc
"Depicted" not "dedicated" flipping auto correct....
Rusellc
Old 30th January 2016, 08:23 PM   #9
Hi all. I am indeed going to have to take baby steps with this but I will eventually get it. I am using the transformer that 6L6 recommended. It has two pair of red/black primaries and the two pair of blue/green secondaries.
I am still in the process of wiring the power switch/power cord/fuse section to the transformer. It looks to me like on the build guide he connects the two red wires to the positive and the two blacks to the negative of the power switch.
My case has a white wire running from the negative of the power switch to the fuse on the back.
Before I go any further I am going to get a grip on this. Which wires do I connect to the power cable itself? You can see on my pic above that I have two loose ends of the power cable coming into the chasis. I am assuming that I would run a wire from the positive of the switch to the positive of the cable and from the negative of the switch to the negative of the cable. Is that correct?
Old 30th January 2016, 09:11 PM   #10
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
oh boy
there are not positive and negative on power switch , same as no these on cable
I strongly believe that learning some basics , prior to proceeding further with build itself , will save you from wasting time and money , and especially will give you more safety while working
fiddling with mains powered gadgets is not exactly safe Lego time .
edit: just one of myriad places for start is http://www.bcae1.com/
look at menu on right side
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Almost, sort of, full range Tannoy 3638 build djn Full Range 8 14th January 2011 04:26 PM
Help needed to sort noise issue with amp build ShinOBIWAN Solid State 28 7th December 2008 05:29 PM
which pass design to build slr 5000 Pass Labs 20 14th September 2008 09:40 AM
sort of preamp for the leach? Flavius Solid State 9 30th May 2003 04:36 AM
Preamp Queastion( sort of) Christian Solid State 1 15th May 2002 06:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
