X-bosoz vs. CCS X-bosoz, how does the sound compare?
Old 18th February 2004, 07:49 PM   #1
acliao is offline acliao
Send a message via ICQ to acliao Send a message via AIM to acliao
Default X-bosoz vs. CCS X-bosoz, how does the sound compare?
Has anyone compared the sound of x-bosoz and ccs x-bosoz? I would like to get some feedbacks from all you experienced builders before I start my project.
Also where can I find the latest schematics on the either preamp? I searched the thread but got information overload as there are too many revisions. Can someone kindly guide me to the right thread or pages?
Thank you very much for your help.
Old 18th February 2004, 08:38 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Running balanced, they tend to be identical. Running with
the input or output unbalanced, the CCS gives better
performance.
Old 19th February 2004, 04:38 PM   #3
Thank you for personally answering my question, Mr Pass.
Old 19th February 2004, 06:18 PM   #4
Alain Dupont is offline Alain Dupont  France
Alain Dupont's Avatar
Playing with SYMetrix
Dou you think it could work like this, or do I need 2 current sources...
Speaking of a CCS X-BOSOZ
Regards.
Alain.
Old 19th February 2004, 07:44 PM   #5
Bricolo is offline Bricolo  France
Bricolo's Avatar
Alain, I'll try to answear your question.
By reading the ZEN V6 article this evening, I think I finally understood how susy works (at least in the sox and aleph-x configuration. I still don't understant the one in the patend )
To explain it briefly (for a better explanation, read the zen v6 article), when one of the 2 polatities has a non linearity, in example a peak, it draws more current from the current source (CCS or resistor). The other polarity is connected to the same current source, so it recive less current (since the drawn current is constant) and this way, also shows a peak on it's output.
The 2 peaks are in phase on the balanced load-> they cancel out.
In conclusion, I would say that both polarities MUST share the same current source
Am I right, Nelson?
Old 19th February 2004, 09:02 PM   #6
Henrik is offline Henrik  Denmark
Alain
You just need one CCS.
This CCS just works fine in my CD player.
Regards Henrik.
Henrik
Old 19th February 2004, 09:13 PM   #7
The one and only
The schematic in the patent was for confusing patent
examiners.
Old 19th February 2004, 09:17 PM   #8
The one and only
I would add some output resistance to this circuit, as I have
occasionally seen some parasitic oscillations with odd loading
on this and similar circuits. I usually use about 221 ohms (I
have a lot of them).
Also, be prepared to trim the values of R113 and R114 depending
on the match quality.
Old 19th February 2004, 11:13 PM   #9
Nelson, Bricolo and Henrick,
Thanks for your advises....
Henrick, I would like to keep a MosFet as CCS, because I have lots of IRF 610...
Have to see Nelson's patent, didn't get time, and on my Macintosh pictures
refuse to load, ahhhh these computers.... better use a Class A, always better results...
Nelson, thanks for the output resistance to be added.
I will make a try this week end, the last components order for my X-BOSOZ
will arrive tomorrow, **** of UPS, they stiked their second poster!
>> trim the values of R113 and R114 depending on the match quality
I will try to match under 0.02 volts for the final pair of 510/610
I think that it won't be a problem.
Thanks to all of you.
I keep looking for new idea's
Alain.
Old 20th February 2004, 07:15 AM   #10
Bricolo's Avatar
Alain: There's no problem in using a FET for the CCS, simply use the same CCS as in the Aleph P, and adjust the resistor for the wanted current.
Nelson: that's what I was thinking BTW, was my explanation right?
X-bosoz vs. CCS X-bosoz, how does the sound compare?Hide this!Advertise here!
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 02:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
BoSoZ pjpoes Pass Labs 3 7th March 2005 06:48 PM
What's that sound? BOSOZ PS blowing up? lgreen Pass Labs 10 23rd October 2004 09:53 PM
How does the BOSOZ really sound? kevyjo Pass Labs 16 6th December 2003 04:28 PM
