Pass Aleph 2 with IRFP 140.
Old 30th December 2015, 08:30 AM   #1
GeeVee is offline GeeVee  Australia
Default Pass Aleph 2 with IRFP 140.
Hi all.
I am fast approaching completion of my Aleph 2 amplifier, and would like comments regarding the usage of IRFP 140 devices.
I will be running about +40 to 45 vdc rail.
According to the data sheet, this should be OK.
My choice for this device is based on nothing more than having hundreds of these devices here ready to go. (Subject to matching).
Could someone please tell me if the usage of this device will be OK?
Kind regards.
George
Old 30th December 2015, 08:42 AM   #2
vivanco is offline vivanco  Italy
I take this opportunity to ask what is the value of voltage drop across the resistor source dell'Aleph 2 ?
I have to make the test measurement on my aleph 2
thanks
Old 30th December 2015, 08:42 AM   #3
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
just go for it
consider decreasing gate resistors to 150-180R
observe stability
don't skimp on 1nF anti-oscillation caps
to vivanco - 500mV across 1R source resistors
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th December 2015, 08:48 AM   #4
hi Zen Mod, What do you mean by capacity anti-oscillation (1nF) ?
Old 30th December 2015, 08:52 AM   #5
Zen Mod's Avatar
show me schematic you're using and I'll show which caps
Old 30th December 2015, 09:00 AM   #6
this is Pass Labs ALEPH-2 DIY amplifier KK-PCB layout
Old 30th December 2015, 09:16 AM   #7
Zen Mod's Avatar
two red dots
also - instead of 390R resistor , put 500R multiturn pot (preset to 390 or so ohms) , for fine output offset set
Old 30th December 2015, 09:29 AM   #8
ok perfect,,, you can also tell me what is the value of volts that must be measured at the ends of the source resistance (1 ohm) ... I ask because I measure an average of about 3.7 V
Old 30th December 2015, 09:46 AM   #9
Zen Mod's Avatar
I already did - in post #3
3V7 is bloooooody too much!!!
something is wrong , not just setting
start new thread , put plenty of pictures and we can (hopefully) help
Old 30th December 2015, 09:50 AM   #10
in your opinion what type of capacitor should be used (I mean those with value 1 nF)
Pass Aleph 2 with IRFP 140.Hide this!Advertise here!
FS: Pass PCB's (F5, Aleph AJ-X, mini Aleph or Aleph 30) nycavsr2000 Swap Meet 2 2nd January 2015 11:15 PM
IRFP 140 Soubstitute with less input capacitance. inertial Solid State 31 29th August 2013 04:28 PM
pass aleph P VS pass X2 first version perusicchio Pass Labs 10 5th March 2004 10:06 AM
IRF 230 or IRFP 140, what's better for AlephX ? Peter Daniel Pass Labs 29 26th September 2002 03:05 AM
irf 240 or irfp 240 for the aleph scu Pass Labs 2 14th January 2002 06:49 PM
