Old 31st October 2004, 01:41 AM   #21
djk is offline djk
djk's Avatar
Supertex makes depletion FETs in TO 92 case styles up to 500V
http://www.supertex.com/products/selector_guides/102
I have run the A40 board up to as high as ±95V with six pair of MJ15024/25 driven by one pair of 2SA1302/2SC3281 for 600W at 4R (class AB).
Old 6th March 2006, 05:02 PM   #22
Smile One Up And Cooking
Its been a while but, I have one channel up and cooking. I have had to turn the bias down as the heat sink gets up to 140F pretty quickly. Based on the original article where "The One And Only" speced .68 ohm emitter resistors and a reading of approx 1 volt between R16-18 some basic math says that each device has about .75 amperes of current flowing through it. I used .47 ohm and once I get more than about 250mv across each emitter resistor the heat sink temps soar.
Old 14th April 2006, 04:56 PM   #23
Talking Hot Coffee ....
It has taken a few years to figure out how to keep my coffee hot while working on various projects in the basement. A freiend accross the street helped out with the heatsink configuration. He has access to a computer controlled milling system. He removed one of the fins and that let us drill holes to mount the devices. Now i just have to finish the other side.
Old 14th April 2006, 05:03 PM   #24
Default Another Picture
Looking from the left ....
Old 14th April 2006, 06:14 PM   #25
The one and only
Nelson Pass's Avatar
Old 14th April 2006, 09:20 PM   #26
jam is offline jam  United States
jam's Avatar
Mr.Pass,
..................burn't pizza?..
Jam
Old 14th April 2006, 09:29 PM   #27
jam's Avatar
Sorry, I ment to say.......Zut Alors!.........Burnt Pizza...
Jam
Old 15th April 2006, 02:31 AM   #28
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
The pizza is on the threshold (of becoming soot...)
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
Old 19th April 2006, 04:58 PM   #29
Default Bulk Bias
Here it is. I had forgotten how much I like bias in bulk….
Old 19th April 2006, 05:01 PM   #30
Default Another Picture ....
rail voltage mike49504 Car Audio 3 11th November 2008 06:12 PM
max rail voltage? MikeFarad Chip Amps 4 11th August 2007 09:44 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 03:56 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 22nd July 2002 11:50 PM
Page generated in 0.10640 seconds (77.52% PHP - 22.48% MySQL) with 11 queries
