Necessary transistors for f5t built
Old 8th December 2015, 09:07 PM   #1
Manolo47 is offline Manolo47  Puerto Rico
Default Necessary transistors for f5t built
Are these available from the Diy store! Thanks.
Old 8th December 2015, 10:34 PM   #2
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Only the jfets (lsk170 lsj74) are available from the store.
For everything else check out mouser or digikey
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 8th December 2015, 11:18 PM   #3
AudioSan is offline AudioSan  Norway
or member h_a for matched sets.
Necessary transistors for f5t builtHide this!Advertise here!
Necessary transistors for f5t built Manolo47 Pass Labs 0 8th December 2015 08:32 PM
Heatsink F5T Feckie Pass Labs 16 6th June 2014 11:23 AM
When does an F5T transition from Class A to A/B? dhenryp Pass Labs 4 7th November 2013 06:05 PM
novel heatsink for F5T gbullimore Pass Labs 19 5th December 2012 10:31 AM
Modifying in-built distortion: transistors in an op-amp feedback loop? chris661 Instruments and Amps 34 8th November 2011 01:26 PM
Copyright ©1999-2017 diyAudio
