Aleph-X builder's thread. - Page 73 - diyAudio
Old 8th September 2005, 10:26 PM   #721
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
In my AlephX, motorboating occurs when bias pots are turned all the way down. I suggest playing with V1, V2 and see what happens.
/Hugo
Old 12th September 2005, 11:56 PM   #722
SY's Avatar
Another question from a friend who is building an Aleph-X. This amp can be run at lower power (or put on standby) by lowering the idle current. Now, if you have a power transformer with multiple primary taps, can you do the same thing by switching taps? That would drop the rail voltage, but I would suspect would not affect the idle current (or would it?). Nonetheless, it does represent a lowering of dissipation.
Is this feasible or is there something stupid that I'm not seeing?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th September 2005, 02:06 PM   #723
wuffwaff's Avatar
lowering the voltage without changing anything else will raise the bias (as experienced when powering up the X through a variac).
I would just turn it off if not needed. Sound quality is very good from cold and putting it on standby wonīt change the warmup behaviour very much (abs. dc offset).
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 13th September 2005, 11:09 PM   #724
SY's Avatar
The issue is not so much standby mode, but using less than maximum power depending on the speakers. So the idea is switching both voltage and speakers, so that it's not necessary to run the same dissipation for (say) speakers that work OK with 50W as one would for speakers that require 150 W. But the amp would be capable of returning to 150W easily when higher power requirement speakers are in place.
Old 13th September 2005, 11:25 PM   #725
wuffwaff's Avatar
ok,
I still think this would be not that simple (but possible). You would have to setup two modes (high power/low power) and have settings for:
1. bias (two pots)
2. ac-current-gain (two pots)
3. diff pair bias (one pot) to set abs. dc offset
This could be done by setting one mode, measuring the resistor values, setting up the other mode, measuring the resistor values and then switching 5 resistors per channel plus the supply voltage
The changes to the supply voltage canīt be too big otherwise other resistors will have to be changed as well.
I would keep it a bit simpler and only change the 5 resistors without changing the supply voltage. If changing speakers only happens two times a year I would fit these resistors in little plug-in modules and change those when needed.
William
Old 13th September 2005, 11:26 PM   #726
SY's Avatar
Danke schoen!
Old 14th September 2005, 09:02 PM   #727
The one and only
Nelson Pass's Avatar
I think that's one of those places where you start using op
amps to actively control the absolute DC offset. As you change
the bias, the absolute DC needs adjusting. The "typical DC
servo" you see in AudioXpress and elsewhere could be adapted
for this job.
Old 14th September 2005, 09:05 PM   #728
SY's Avatar
Hmmmm, servo.... servo.... where have I seen this before?
Old 14th September 2005, 10:20 PM   #729
The one and only
MST3K! Tom Servo.
Old 14th September 2005, 10:23 PM   #730
SY's Avatar
No, Crow.
Copyright Đ1999-2017 diyAudio
