#541 |
Account Disabled
That is designed as a passive crossover, although the author shows how an active version can be made. I intend to use a passive versin, but I'm not sure if the gain of the Aleph-X is enough. The DAC with volume control set to maximum outputs buffered 7 V peak-to-peak (balanced). What fraction of rail voltage does the Aleph-X clip at?
#542 |
Prune and byteboy,
thanks for the replys, appreciate it! |
#543 | |
The one and only
of the Mosfet and 1 volt Source resistance. |
#544 |
I am planning to build a pair of low power Aleph-x's (20-30 Watts)
How many Fet's should i use 4 or 8. For the psu i plan to use a 350VA tranny for both rails and a MB3510 bridge and a CLC filter with 47000uF/3mH per rail. Heatsink (per channel) is 260 * 200 * 40 (0.38C/W) and a separate heatsink for the bridges. Any suggestions? |
#545 |
I am using HiFizen's boards for my Aleph-X and I am using 12 IRFP240 fets per channel. I would like to use terminal blocks on the PCB to connect to the external IRFP 240 fets. A 5mm pitch pcb terminal block fits perfectly in the holes where the single IRFP044's were to be connected. On my external CSS and Gain boards I have mounted the gate resistors and source resistors. I can put some jumpers on the board so the terminal blocks will work. My question is if I have to run the sense lines from source on the CSS and Gain board or can I use the sense line on the PCB which is connected thru the sense resistor to the source at the terminal block?
----------------------------------------------- Kilowattski |
#546 |
Cancel my last question because after I thought about it I realized I can't do what I wanted with the sense resistor. How have others handled the sense resistors using HiFizens Aleph-X boards with external transistors?
#547 | |
240VA transformer per channel, schottky rectifiers and 80000µF per channel, no coil. works well for half a year now you get better distribution of heat and probably a bit less distortion with 8 transistors m. |
#548 |
Thanks Dieringe.
I was just wondering if i had enough bias current per Fet to achieve good lineairy when using 8 devices. According to the axe spreadsheat the heatsink will get to around 67 C. The junctiontemp will be 91.8 with 4 and 79.8 with 8 Fets. What kind of bias and current gain settings do you use and what is the value of youre source resistors? btw.the heatsinks are black. |
#549 |
Kilowatski,
I mounted the sense and ground resistors to the heatskink using a copper bussbar. This worked quite well and allowwed me to use many resistors in parallel. These resistor really don't get that hot so where you mount them isn't critical as long as it get some air.
Living Life Doing the Waltz in 4/4 meter. |
#550 | |
I use 2x12V transformers to get maximum output at 8ohms, should be about 1.5A per transistor(?). low voltage -> higher current... dont know if that would be enough for 8 tr.(0.75A) My source resistors are 0.33 ohms I have something like 65°C at the heatsink too... m. |
