Aleph-X builder's thread. - Page 260 - diyAudio
Old 19th May 2017, 11:19 PM   #2591
muhy3 is offline muhy3  Australia
Originally Posted by Dennis Hui View Post
Hi Vlad,
Do you recall how the matching for the diff pair Q5/Q7 was done?
Another thing I noticed is that the total current through R23/R25 seem a bit low,
even with V2 at its lowest value. Can you confirm your part values for D1 and R17?
Dennis
I purchased matched Q5/Q7 from Jim's Audio. I have a few spares, so I'll set up tonight and match them myself and replace once matched.
D1 = 1N5239B and R17 = 1.5k ohm
Thanks!
There used to be a time, when penguins filled the sky!
Old 20th May 2017, 12:08 PM   #2592
OK. Try measuring and matching the Vgs of the IRF9610 at around 12mA.
Also can you please check for voltages across D1 and R24.
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 21st May 2017, 12:08 AM   #2593
Dennis
D1 = 8.5v
R24 = 4.6v
Vgs of IRF9610 was 10mA from Jims Audio.
The parts bin I have, I was able to match to 15mA.
D1 should be 9.1v shouldn't it?
Old 21st May 2017, 04:28 AM   #2594
So I bought a bench top PSU and went through to try and match Vgs for the 9610 from Jim's Audio... turns out none of them matched! I had a stack of others, and matched a couple exactly, to like within 0.001v. It didn't seem to make a difference to the circuit. To me it seems like the overcurrent protection on Q9 is being triggered with the volts reading 0.65 across R39... but 0.15 across R13
Sent from my iPhone using Tapatalk
Old 21st May 2017, 01:20 PM   #2595
Eric is offline Eric  United States
Eric's Avatar
Yes, D1 should provide forward voltage of about 9v (give or take a few tenths). It is critical that Q5 and Q7 be as closely matched as possible. 0.001v is about as good as it gets. If you were using poorly matched transistors the first time around, this could be part of the problem of large offset that won't move with V2 and overheading output resistors.
I'm still suspect of Q4 and Q9 given the short you found.
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Old 22nd May 2017, 05:08 AM   #2596
hates ground loops
Rodeodave's Avatar
I have a question regarding the output loading resistors (R1/R4 and R44/R45 on the Aleph-X rev 1.0 pcb). As I'm building my Aleph X specifically for driving planar headphones (HE6), the load impedance seen by the amp will be a flat 50 Ohm. How should I size the loading resistors? From what I've gathered, the typical value used is usually about four times the impedance of the speaker's impedance, so about 32 Ohm for an 8 Ohm speaker. In the case of a 50 Ohm impedance that would amount to 200 Ohms, which would practically barely load the output... So, what do? 100 Ohm maybe?
Also, about the McMillan resistors (R46/R47), is there any sense in trying to omit them? Or are they most definitely needed to insure low and steady DC offset at the outputs?
Gravity - Making the G since 13.7 billion B.C.
Old 22nd May 2017, 06:19 PM   #2597
Eric's Avatar
I don't have definitive answers for your questions. My R1/R4 and R44/R45 are set to about 78R with five 390R resistors in parallel. Guess this puts me somewhere above 8x my speaker impedance. As for the McMillan resistors, there was a great deal of discussion earlier in this thread or the other huge Aleph-X thread. The discussion that I remember is that they solve a problem related to offset stability (though I don't remember the details at this point). You can try building without them, but my guess is that you'll end up putting them in anyhow.
Copyright 1999-2017 diyAudio
