#2031 | |
I removed C12 and C13 (220uF Panasonic FC) I also removed C9 and C10 (3n3) lag cap I don't use these caps in my bigger amp also. Now it is much better. Power out with 20kHz and 1% THD is 40W/8Ohms now. Before it was 20W/8Ohms. Power out with 1kHz and 1% THD is 65W/8Ohms now. Before it was also 65W/8Ohms. So I still have problems with higher frequencies but much better than before. Last edited by JBL4435; 15th November 2010 at 10:32 PM. |
#2032 | |
I wanted to check the behavior in full power and to get full power I need 2.8V unbalanced in. Didn't really nobody look into THD at full power with frequencies above 1kHz? Last edited by JBL4435; 15th November 2010 at 10:20 PM. |
#2033 |
I have no way to measure THD with my (borrowed) scope, so no, I haven't looked at THD before. I have noticed that high frequency output tends to distort more quickly than lower-frequency output for the same input level, though I haven't made a formal study of it yet. Perhaps I'll have a look at this the next time I have the scope hooked up...
Funny, I have measured maximum output into 4ohms and 8ohms lots of times, but I never actually measured the magnitude of the input signal that provides my maximum undistorted input signal. Guess its time to get the scope out again soon... I still think you'll find benefit to use fewer output transistors and drive them with greater power (20w or so power dissipation).
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages. |
#2034 | ||
Many thanks to all that tried to help here!!!! I'll try to experiment with fewer FET's |
#2035 |
That's quite the nice toy that you've acquired! I've been trying (to the extent possible) do things "on the cheap," so I've been borrowing equipment from the EE lab on campus.
Looks like I need to drag out the scope tonight or tomorrow to do some more learning. In reference to your removal of caps, I found square wave distortion when c9 and c10 were removed (detailed on my web page that you've been reading). I have never run the amp without C12 or C13...
#2036 | |
#2037 |
Hmmm... I'll have to give it a go without C12 and C13 and see what differences show up in the measurements and audio performance.
Ok, after carrying the 70lb beast upstairs and waiting for it to warm up, I made some measurements of input and output voltages at the visible onset of clipping in the scope. Here is what I found: 1 kHz clip onset, 3.66v peak-to-peak input, 150w output into 4 ohms 5 kHz clip onset, 3.64v p-p input, 139w into 4 ohms 10 kHz clip onset, 3.05v p-p input, 96w into 4 ohms 15 kHz clip onset, 2.80v p-p input, 80w into 4 ohms 20 kHz clip onset, 2.56v p-p input, 65w into 4 ohms These measurements were made with 22.4v rails and 9.4A bias current. Measured voltage drop across source resistors averages 0.515v. Final heat sink temp is about 55c. I stand corrected, 2.8v input is not too high of a signal level. I thought for sure this was part of your problem. I did, however, duplicate your situation of reduced power output as input frequency increases.
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages. Last edited by Eric; 16th November 2010 at 01:32 AM. |
#2038 | |
Without C9/C10, C12/C13 it got significantly better. As I removed all 4 caps at one time I can't they which ones are "bad". We will have to wait what you find when removing C12/C13 only. This way we will know. |
#2039 | |
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert |
#2040 |
| Page generated in 0.09364 seconds (69.58% PHP - 30.42% MySQL) with 11 queries |
