Old 14th November 2010, 03:41 PM   #2001
In post 1995, is that your calculated bias or the bias actually measured on both sides of the amp across the source resistors?
Living Life Doing the Waltz in 4/4 meter.
Old 14th November 2010, 05:11 PM   #2002
JBL4435 is offline JBL4435  Germany
Measured Bias
Old 14th November 2010, 05:16 PM   #2003
Good. As before would be interesting to see the output of the diff pair.
Old 14th November 2010, 05:26 PM   #2004
First of all thank you for trying to help me. I can check the output of the diff pair only tomorrow. It would be nice if you can return
Just for thinking about it meanwhile, do you have an idea what could be the problem?
Old 14th November 2010, 05:32 PM   #2005
Since your bias is correct, offset both absolute and relative is within range, I would suspect that the fault lies within the drive portion of the circuit. Look for unmatched feedback or ac gain.
Distortion is apparrent in all three of your traces above but becomes obvious at the higher power levels.
Old 14th November 2010, 05:33 PM   #2006
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
gain is shelving down with frequency ;
it's possibly coincided with output mosfet's capacitance ......
what's current through input LTP ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 14th November 2010, 05:44 PM   #2007
Very good point ZEN. That would be another point to check.
Old 14th November 2010, 05:48 PM   #2008
Zen, can you explain this "LTP" I'm not good in abbreviations.
Do you mean it's a given that the power output decrease with rising frequency?
We are talking about 20kHz, not 100 or 200.
Old 14th November 2010, 06:00 PM   #2009
LTP = Long Tailed Pair. What ZEN is pointing at is that the current should be measured on the FETS in the LTP. If the current is too low, the capacitance presented by the output devices would attenuate the high frequecy. The attenuation would get worse as the frequecy increases.
Could you point me to the correct schematic for the "Green" boards. It has been several years since I built my x100's. (Like in 2004).
IIRC Mine is built with IRP244's
Old 14th November 2010, 06:10 PM   #2010
I'm no novice but how do I measure this?
I use the boards used here
Aleph-X 100w Amplifier Construction Notes
Schematic
http://www.facstaff.bucknell.edu/esa...es/axschem.jpg
Board
http://www.facstaff.bucknell.edu/esa...es/pcb-ext.jpg
Copyright ©1999-2013 diyAudio
