Aleph-X builder's thread. - Page 160 - diyAudio
Old 21st February 2008, 11:59 AM   #1591
Is the reason you donít like the resistor/thermistor network in series with TL431 bias generator due to the increase in AC (as well as DC) impedance and the need to bypass with a capacitor to reduce this effect? Or is the motivation behind wanting to place the resistor/thermistor network in the TL431 reference loop to increase the effectiveness of the thermistor? Either way I agree that this is a perfectly reasonable way to do things if the intent is to thermally compensate the output stage by altering the bias.
The intent in both Dirkís and my circuit is a little different. We are looking for an effective bias voltage that is lowest when the amplifier is in standby, i.e. the FE is powered down, increasing to its maximum when the amplifier is switched out of standby to help speed the warm up period. As the temperature increases, the desire is to reduce the bias current to the normal working value. Direct compensation of the output stage temperature, as might be achieved by mounting the thermistor on the output heatsink, is not the idea.
I canít see how to achieve these aims with the thermistor in the TL431 reference loop, particularly in terms of the relatively abrupt behaviour required when switching in and out of standby. If we rely only on the thermistor, the bias current will remain at a high value when exiting standby until the chassis, and hence the thermistor, cools sufficiently. I donít feel this is particularly desirable, hence the insertion of the series resistor.
No doubt there are better ways of achieving this but so far they havenít occurred to me. All suggestions for better alternatives are very welcome
Ian.
Old 21st February 2008, 04:33 PM   #1592
gl is offline gl  United States
My understanding of thermistors used in such locations is that the major response is to the ambient temperature inside the case. Since (in a class A amp) the source of heat inside the case comes almost entirely from the output section, I would therefore conclude that this thermistor is present to provide coarse bias regulation for said output section. I don't think things are more complicated than this.
Graeme
Old 21st February 2008, 04:41 PM   #1593
IMO the the thermistor circuitry would have been the last thing tweeked in the final design of the amp. You can't finalize the response curve until the circuitry is installed in the case, so at least one or two or the resistors would be present to allow fine tuning of the thermistor response "in place".
For a DIY effort, that presumably would have different casework, you would have different circuit values around the thermistor or perhaps no thermistor at all. Once again I would maintain that this whole subject is getting more attention than it deserves.
Graeme
Old 21st February 2008, 05:23 PM   #1594
Graeme,
I agree with you on most counts with the possible exception of this getting more attention than it deserves. It deserves attention only because it may be the key to how to handle the standby feature (if this is important to you). Standby may be useful in helping eliminate thumps from the speaker due to the SE bias.
Ian.
Old 21st February 2008, 06:08 PM   #1595
Hi Ian,
Why do you think that the SE bias mechanism would cause thumps?
Graeme
Old 21st February 2008, 08:02 PM   #1596
When you switch off the front end in stand by mode, you have to leave the putput stage in a small conducting state. There are SE-bias resistors which are connected between output and negativ supply voltage!
You have to blow enough currrent into the output stage for not seeing the negativ rail voltage at the outputs. This is be done with the 10k resistors which are connected between the gates and the rail voltages. Alternatively you can put a switch between bias resistors and negativ supply and switch them off when using the stand by mode.
Dirk
Old 21st February 2008, 08:40 PM   #1597
To the voltage bias circuit:
Yes, the dimensions of the parts will be individuell and depends on location of the thermistor and other facts. Before you start implementing such a thermistor compensating network, I would do three measurements with the complete amplifier (and only a normal voltage reference as bias):
- Which bias voltage is needed to get full / maximum bias current when amplifier is cold.
- Which bias voltage is needed to get full / maximum bias current when amplifier is hot.
- Which bias voltage is needed to get minimum bias current and 0V at the outputs. (think this should be measured when the amp is hot, because then it doesn't matter that the voltage bias will rise a bit when it is cooling down)
With this three individuell values and a choosen thermistor it should be possible to calculate the series resistor and the resistor network.
When it is implemented you can correct the bias a bit with the trimmer.
Dirk
Old 22nd February 2008, 05:19 PM   #1598
Originally posted by gl
Hi Ian,
Graeme
It probably will not of itself in the sense if both halfs of the 'bridge' are balanced then any offset should be common mode and hence will not be seen by the speaker. I was just concerned that everything will need to both balance well throughout the startup period as the PS caps charge as well as steady state.
Ignore me
Ian.
Old 22nd February 2008, 05:25 PM   #1599
Dirk
As per my previous post, the negative supply due to the SE bias is not a problem for the speaker as it will see it as a common mode signal. That said, I believe I recall Nelson saying that he bleeds additional current into the output stage on standby to reduce the common mode voltage to close to zero. Just turning the PP devices on will not do it for the relatively small standby consumption we are looking for. I don't know, but I would assume this is done by making the 10k resistor to the +ve supply of slightly smaller value. Perhaps using a parallel resistor? This would allow another, similar resistor to be switched in with the FE supply to balance things in normal operation if desired.
Ian.
Old 23rd February 2008, 01:11 PM   #1600
Ian,
yes, that's clear, the speaker would not see the negative supply voltage.
My answer was short and imprecise (difficult for me to come to the point in english!).
It is the working absolute offset (generated by switching on and off and maybe different on both bridge sides) which can result in moments with to much differential offset.
Also it is handsome to get 0V absolute offset in both operating methods (stand by and power).
But I have to disagree with you about the answer of Mr. Pass:
He explained that the implementation of the 10k resitors (between gate and supply) would result in outputs which float at about -4V ABSOLUTE offset. Bleeding enough current into the system would rise it close to 0V. (Post number is 1451 but better to start with 1445 in this thread)
I don't know if I have interprete it in the right way, but it seems to me that only this two tools (10k resistors and high enough bias voltage in stand by) would do the "self balance" between N- and P-mosfets.
Other point:
Have thought about the thermistor network. It believe it is easier to calculate this network when you use a single resistor in series with the TL431 and put the thermistor-resistor-network between cathode and reference pin. Then the series resistor can be calculated independently of the thermistor network.
Dirk
Copyright ©1999-2017 diyAudio
