#1451 | |
The one and only
is loaded by 10K to each rail, the equivalent of 5K to ground. This results in outputs which float at about -4V or so (absolute, not differential), if the front end is shut downand this is fine, but for esthetic reasons we bleed enough current into the system to raise it close to 0.
#1452 | |
The one and only
distortion. If so, I don't recall having seen such a thing, that is to say a short disappearance of 3rd harmonic on a swept power curve. It might be an artifact of the test.
#1453 |
> I assume that K2 and K3 represent 2nd and 3rd harmonic
K is Klirrfaktor in German, or distortion factor if translated directly. So K2 is 2nd harmonic, etc. Patrick |
#1454 |
Nelson,
Are you saying here that the SE bias in the output stage of the XA100.5 is supplied through a passive load and not an active CCS? Cheers, Graeme |
#1455 |
Many, many thanks to the master!!!
javascript:smilie(' ')worship (I'm doing something wrong with loading a smilie, sorry...) Try to understand if this is done with the front end outputs (from p-ch and n-ch devices) connected together or with voltage bias between them.... I need a bit more time to think about it......... The switch posibility (X.5) is done with the negativ front end voltage - only a resistor from there to the base. When front end is shut down SE bias is turned off - that's it :-) Hi Graeme, I would say yes, CS not CCS.... Dirk |
#1456 |
ý can how make line input to balanced input ?
#1457 | |
The one and only
#1458 |
Thank you.
#1459 | |
In 2) above I interpret your response as 2 (sides) x 20 (parallel sets) x 2 (MOSFETs per set). Should that be 2 x 10 x 2 for an XA100.5? Graeme |
#1460 |
The one and only
Yes, 40 devices / ch
| Page generated in 0.08775 seconds (65.97% PHP - 34.03% MySQL) with 11 queries |
