Aleph-X builder's thread. - Page 119 - diyAudio
Old 29th December 2006, 01:32 AM   #1181
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by Nixie
The only Babelfish thread I found is 32 pages long. Can you be more specific?
http://www.diyaudio.com/forums/showt...18#post1066818
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 29th December 2006, 02:37 AM   #1182
Nixie is offline Nixie  Canada
Banned
What is EI72? 7x2 cm coil crossection in the laminations?
Anyway, that's certainly too large for me; I'd like about 1 mH, as the capacitance multiplier in the next stage takes leftover ripple down several orders of magnitude.
Old 29th December 2006, 05:38 AM   #1183
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
MCM Electronics carries air core inductors that i've used before. I just checked and they have 1.00 mH and 1.50 mH in stock. The part i used
was the 2.00 mH that Mr. Pass recommended in the SOZ article. Some people complain that they look cheap, but they've worked fine in my ZEN, Aleph 2, and Aleph-X amps.
MCM Electronics
just do a search for air core inductor.
Old 29th December 2006, 06:06 AM   #1184
Banned
An air cored inductor would need more turns and thus would have larger DCR for the same wire gauge.
Any help calculating EI core for a 1 mH? I have access to various old transformers as well as a manual winder.
Old 29th December 2006, 07:54 AM   #1185
Hi
I started out with 47mf 0.11 Ohm 47mf 0.11 Ohm 47mf.
With 9A and the resistors get realy hot.
Then I change to a I Coil from intertechnik 1.5mH
http://intertechnik.de/index.html/JT...3761&suchwort=
The temperature of the coil is 100 C and I have 20mVTT rimple at 9A
Rob
Old 29th December 2006, 08:04 AM   #1186
metalman's Avatar
For my Aleph-X's I used the Hammond 156B Open Choke. 1.5mH 0.07ohm, rated for 5A. Cheap and relatively small too.
Old 29th December 2006, 09:36 AM   #1187
Emeric is offline Emeric  France
Rob, what was the power of your 0.11 Ohm resistor ?
I want to use 2 resistors (CRCRC), one 1.5Ohm / 50W and one 1Ohm / 50W. It is less expensive than a choke (for me). (about 50€ for the resistor and the heatsink and for 2 amp with 4.5A of bias).
The ripple will be of 2mV.
Old 29th December 2006, 09:57 AM   #1188
wuffwaff's Avatar
are you shure it is less expensive? You´ll need a bigger transformer, bigger heatsinks and you will draw more current (so your electricity bill will be higher). The temperature inside your case will also be higher.
The Torobars cost around 13€ a piece depending on source and will give a better result.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 29th December 2006, 04:56 PM   #1189
Hi Emeric
I used 2 10W ceramic 0.22 Ohm resistors parallel and connected on the elco.
They heat up the elco to much so I changed the layout and now use a Coil.
Rob
Old 29th December 2006, 05:30 PM   #1190
Hi william and Thanks for your repply,
If the torobar is at this price, that's great !
But Is it easy to buy it ? (for france)
What model do you advise me for 4.5A / 20V and 50mV ripple max ?
Copyright ©1999-2017 diyAudio
