#1111 |
Banned
I've very large mica sheets of the same thickness as used in the usual insulators.
My question was more regarding say capacitance between the now-connected to drains bus bar and the heatsink, or the inductance of the long bus bar, etc. |
#1112 |
Formerly "jh6you". R.I.P.
The larger plate area increases the capacitance.
Might lose high frequencies. . . all. . . ?
#1113 |
I am interested in building the Aleph x , low power version and would like to know where I can get circuit boards.
j
"If every one is making wheels , why make wheels ? " Steve Jobs |
#1114 |
Banned
I've some spares, but see if you can find another source first, as I'm not quite certain I won't need them.
#1115 |
I have two 1000VA 35v secondary Plitron transformers at home that I bought about five years ago. I took them out recently and decided that I would like to build a power amplifier with them. I searched the forums and have done quite a bit of reading over the last four weeks on the SKA, Aleph-X, and various ChipAmps. I haven't found anyone using the transformers that I have with the Aleph X but would like some guidance as to how appropriate they are for the job as well as a possible source for boards to ease construction. if they are not going to work, perhaps a suggestion as to what project to build as it seems a waste to not use my big beautiful heavy chunks of copper for something.
Thanks! |
#1116 |
diyAudio Moderator Emeritus
I can't comment on other amps but I believe 35V is a bit high for AlephX.
/Hugo |
#1117 |
I too think that the voltage is too high for the Aleph-X. However, the transformers would make a great basis for a pair of Aleph 2's.
Graeme |
#1118 |
Hello , Pardon me for this rudementary question. I am in the process of digesting Grey Rollins original 15v Aleph x schematic and was wondering about some of the resistor values... 392 ohm,221 ohm, 68.1k ohm. How do you obtain these uncomon values?
J
#1119 | |
uncommon? nope- common values in 1% metal film - E48 (is it ?) nomenclature
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#1120 |
sory i think I didnt check around enough, I just looked at MCM , seems like Mouser has a plethora of said values.
Thanks J
