Aleph-X builder's thread. - Page 107 - diyAudio
Old 16th February 2006, 10:39 AM   #1061
panos29 is offline panos29  Greece
panos29's Avatar
Send a message via ICQ to panos29 Send a message via Yahoo to panos29
Default J-fet Aleph-X anybody?
I very well understand that I may be a bit off topic but I thing thats the right place to ask a silly(maybe not) idea that came to my mind today.
Of course as i did not red all the threads, somebody else may have though of it before.
So here it is, since I only need less than 10W of power for my horn loaded 15" tannoys, I would like to ask if it is possible to build an aleph-x using extremely low voltage, something like +/-8V lets say. I know this is not possible with IRFP240s as the point falls out of linear region.
BUT what if we try the lovely Lovotech's Jfets that happen to work very linearly in that voltage region?
Panos
Old 16th February 2006, 04:53 PM   #1062
gl is offline gl  United States
Hi Panos29,
Look in the main Aleph-X thread. There was a large discussion on a JFET front end for the Aleph-X. It eventually died. There were too many power dissipation related issues.
You are correct about the MOSFET non-linearity issues with low rail voltages. It's been discussed a lot.
Other than that your idea of a JFET input / JFET output low power Aleph-X is a good one and I would encourage you to go for it. I figure you're not the only one that's had this idea.
Graeme
Old 17th February 2006, 05:25 AM   #1063
lgreen is offline lgreen  United States
lgreen's Avatar
Default Aleph X High Power Connections
Hello everyone, I've been looking at the A-X high power connections to multiple MOSFETs. Seems like there is some talk about how to connect these but nothing definitive. So I have looked at all this and I think it goes as follows, let me know if this is wrong-
Aleph X Schematic (left side) Multiple Outputs
Here are some options for using this information to connect Grey's boards to multiple output devices (again please post if any of these are incorrect).
Aleph X Multiple Devices Option 1
Aleph X Multiple Devices Option 2
Aleph X Multiple Devices Option 3
I think I'll use Option 3, which appears to be the best.
- thanks
(Killowatski- do the output boards look familiar?)
Old 21st February 2006, 04:56 PM   #1064
lgreen's Avatar
Default a little help?
Is this a hard question?
I did not mean to shut down the thread for 5 days.
Old 21st February 2006, 07:54 PM   #1065
wuffwaff's Avatar
itīs not a hard question. Maybe itīs too simple?
I used option 4 wich connects the V+ from the board edges like you connected V-
The rest is OK although you can leave out the jumpers for the gate resistors and connect the wires on the other side.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 21st February 2006, 08:45 PM   #1066
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Default Re: a little help?
I looked but the links didn't work and still don't. Timeout’s after 10'.
I'm sure William's answer will be adequate.
/Hugo
Old 21st February 2006, 09:51 PM   #1067
lgreen's Avatar
Default links
? are you sure the links don't work, i just tried all 3 and it works for me.
Old 22nd February 2006, 03:55 AM   #1068
lgreen's Avatar
Default Re: Aleph X High Power Connections
I've edited the links- please don't wait 5 more days to tell me this does not work.
- thanks
Old 22nd February 2006, 10:57 AM   #1069
Netlist's Avatar
Sorry, I can't make them work.
Even http://www.parttimeprojects.com/ gives a timeout.
/Hugo
Old 22nd February 2006, 11:40 AM   #1070
BobEllis's Avatar
the links all work for me
Copyright Đ1999-2017 diyAudio
