#1021 | |
I have taken pictures, see this thread |
#1022 |
Hi Nixie,
Thank you for the idee's. Option 1 is not easy to do for this moment. In fact you should use a potted transformer. Option 2 is no option because i already build the amps. It's no point of discussion that a seperate (raw)power supply is better, but practical ... Option 3 is "easy" to do. I read the snubber article of Jim Hagerman with great interest and i will try it. B.t.w. i use two full wave bridges with HFA25PB60(ultrafast soft recovery) rectifiers. Some guy's use a rc snubber of 100R+100N parallel. Maybe that's a good start? |
#1023 |
Nice and solid looking amp. You really paid much attention to the bridge. Where are the outputs? We need more pictures, for sure in the passdiy gallery.
![]() /Hugo |
#1024 |
Hi Guys
Theese are really exelent. http://www.evoxrifa.com/cap_catalog/...en_info_rc.pdf http://www.evoxrifa.com/europe/specs_rc_caps.htm
air is analog
#1025 |
Hi Hugo,
The pictures were already posted in a other thread. In fact this is a better place. "Start me up..." AlephX with relais control and powermanagement. The evox rifa caps shoud be excellent but this weekend i will try something from my "junk box". If there is any result i order rifa's. Gr. Johan. |
#1026 |
Hi Gents,
Last saturday i tried snubber filters around the bridge rectifiers but it had NO influence on the small hum at the output of my ax's. I'm afraid i must live with it. |
#1027 |
I'm using triple the # of output devices on my A-X.
I see that some resistors need to be triplicated off board as well. Which ones need to be (a) off board, and (b) triplicated? - thanks |
#1028 |
Banned
joho, don't put the snubbers around the rectifiers. Read the actual link I posted on the previous page; an RC or RC+C snubber should be across the secondary. Also, it's best to use a scope to find the right part values, unless you know the actual values of transformer's parasitic reactances and can use the formulas to calculate them.
#1029 |
Hi Nixie,
I didn't interpret the positioning of the rc-snubber on this way. I read the article again and i suppose with "secondary" you mean one rc or rc+c across the output of the bridge(between + and -)? Johan. |
#1030 |
Banned
No, it's an RC, or RC and a C across the secondary of the transformer, before the rectifiers.
| Page generated in 0.13056 seconds (79.18% PHP - 20.82% MySQL) with 11 queries |
