Aleph-X builder's thread.
Old 15th June 2018, 03:20 AM   #2661
GeeVee is offline GeeVee  Australia
Hi Eric
Thanks for your response. Greatly appreciated.
I reckon its safer to run the amps with the prescribed 22V rails. On reflection, my speakers are a nominal 4 ohms, so definitely better to go for higher current.
PS: do you see any issue with using the IRF 140 Fets, instead of the 240 as is commonly used?
Kind Regards
George.
Old 15th June 2018, 06:03 PM   #2662
Eric is offline Eric  United States
Eric's Avatar
I don't have any personal experience with the IRF140 devices. I know others have used 044, 240, and 244 with good results...
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 1st July 2018, 03:46 PM   #2663
Jakeh is offline Jakeh
I have 6 unused original v1.0 boards now going spare if anyone is still looking.
Old 1st July 2018, 04:30 PM   #2664
Earthquake is offline Earthquake  United Kingdom
Default PCB
Iíd be interested in purchasing the boards please PM me with the cost etc
Old 1st July 2018, 06:50 PM   #2665
mpmarino is offline mpmarino  United States
mpmarino's Avatar
Kind Regards
George.
I've used IRF140 in every aleph I've done. Just keep in mind it's a 100V device.
Bonus: you need less of them.
Crazy Yankee.
Old 16th July 2018, 06:04 AM   #2666
da9735 is offline da9735  Sweden
I’d be interested in buying please PM me if still available!
Old 26th July 2018, 12:08 PM   #2667
gorgona1977 is offline gorgona1977
Hello. I collected my Aleph X own and ran into a problem. Periodically, I have a slight crackling and rustling in the speakers. And it can appear at any time and just disappear. Or in the left channel, or in the right channel. Sometimes not strong, sometimes stronger. It does not depend on the temperature regime. May be immediately after switching on and can be after warm-up. And this sound is not like a rumble from an earth loop or overexcitation. More like a bad contact somewhere. I disassembled the amplifier, did not detect anything visually, the suspicious places on the boards were lost again, but the problem did not dare. What could it be? Thank you in advance for your help!
Old 26th July 2018, 12:25 PM   #2668
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
usual things - check all mosfets for resistance between mid pin (drain) and heatsink ,check torque of screws, reflow any suspicious solder joints
often you can't see bad solder joint , but reflow helps
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 1st August 2018, 05:28 PM   #2669
Flushing Shadow is offline Flushing Shadow  Netherlands
Iím looking for the BOM for the original pcb, canít seem to find any info in the wiki or am i just looking in the wrong corner?
Thanks in advance!
Old 1st August 2018, 06:32 PM   #2670
Zen Mod's Avatar
define original pcb
Aleph-X builder's thread.Hide this!Advertise here!
