Aleph-X builder's thread.
Old 2nd February 2018, 05:41 PM   #2631
metalman is offline metalman  Canada
metalman's Avatar
Originally Posted by Eric View Post
I've never used any speaker protection with my set of Aleph-X amps. Never had the need, the relative DC offset has always been rock solid and well behaved.
+1 (Me too!)
Darn career gets in the way of my audio addiction!
Old 4th February 2018, 06:02 PM   #2632
yoke is offline yoke  Croatia
yoke's Avatar
mine too
but I'm at crossroad thinking to build one more small AlephX or to sell the one I have
the potential buyer would like me to place some loudspeaker protection at the output..so...
right now I don't have any fuse at all...maybe I should add that one too
I'm not shore will I sell it at all...have to think how to proceed
Old 4th February 2018, 06:13 PM   #2633
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
in that case ......... no , it is not possible to use speaker protection with Aleph X
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 4th February 2018, 06:18 PM   #2634
yoke's Avatar
I have to agree with you
Old 7th March 2018, 07:10 AM   #2635
neno70 is offline neno70
Default ???
hello, sorry if I go back again on this subject but, I found here in the first pages this protection circuit x the speakers, can you use? and about the pcb of soft start and protection cases, sold here in the store, and valid x Aleph X, I liked that introduces the delay of a few seconds. Thank you
Old 7th March 2018, 09:58 AM   #2636
Zen Mod's Avatar
yes , you can use that circuit for protection
Old 8th April 2018, 07:59 PM   #2637
yoke's Avatar
in that case you can use even IRF510 in output ....... that thing will be fast as lightning
Can I use irf610 insted 510 ?
I just found some "matched" laying around...don't know which of those are matched to each other...but...
Don't know the brand...but
Old 8th April 2018, 08:41 PM   #2638
Zen Mod's Avatar
6 is having some more capacitance than 5 ..........
though , Pa originally used 6-es everywhere
bought them by container , so why not ......
Old 9th April 2018, 06:18 AM   #2639
yoke's Avatar
tnx ZenMod
Old 9th April 2018, 04:15 PM   #2640
yoke's Avatar
O.K.
some simulation
the starting point are 15V AC transformers from AlephMIni
those would give me like 18V DC on load (if I remember correctly pass x1.2 formula)
So with 18V and 2A bias, I would need 0.5ohm source resistors
and will have 18W dissipation per mosfet
If I read right IRF610 are capable of 36W max...so...I'm ok...
All that will give me like 8W on 4ohm and will drop with impedance.
The plan is to make new case for amplifier that will have 8W and 60W AlephX in one enclosure.
It is more convenient for me to have it in one case then in two as it would take less space.
What could be the problem is that I will have to rotate heat sinks from vertically to horizontal which will not be optimal heat sink orientation but I hope it will do the trick (other wise I would get too large case which would not fit into my ''apartment'' )
I have Fischer SK41, 150mm, which are ok for 65 to 70W of dissipation
so I will place them horizontally X 3 to get like 450mm deep case ( if I would place them vertically, side by side, it would be like 540mm+front plate and it would need at least 600mm space )
(will have 6 X SK41 per case)
Here is the picture of my AlephX
And some pass amplifier with ''unstandard'' heat sink orientation
The question;
As it's been a while since I build my AX, should I stick with schm from Eric's page
http://www.facstaff.bucknell.edu/esa...es/axschem.jpg
or should I change some values ?
I have original green AX PCB
tweeter is scanspeak 2904/7000
Aleph-X builder's thread.Hide this!Advertise here!
