Aleph-X builder's thread. Aleph-X builder's thread. - Page 244 - diyAudio
Old 12th April 2014, 09:48 AM   #2431
dieringe is offline dieringe  Germany
Is that the "Forward Transfer Admittance" in the datasheet?
LTP?
What is the ztx for? Oh I guess to get a CC for the single fets
Old 12th April 2014, 10:08 AM   #2432
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Long Tailed Pair
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 12th April 2014, 11:43 AM   #2433
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
LTP?
yup - Yfs
LTP , as input pair , arranged in
regarding ZTX ..... I really don't know which exact schmtc you're referring to
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th April 2014, 11:48 AM   #2434
Eric's replacement:
http://www.facstaff.bucknell.edu/esa...JFET-input.jpg
also seen here a few pages before
Old 12th April 2014, 12:16 PM   #2435
Zen Mod's Avatar
for that - any universal PNP
BC556 , BC557 , BC560 , BC327
they're cascodes for Jfets
and , you don't need two of them in parallel - just one per leg , especially if using BC327 , tough bugger
Old 12th April 2014, 12:31 PM   #2436
Replacement is clear
So you have to cascode a jfet as opposed to the irf, it's not just because it's multiple jfets in parallel
Old 12th April 2014, 12:40 PM   #2437
Zen Mod's Avatar
you don't need to cascode them with your 15V per rail
generally - cascoding is usually (for cascoded par) either as voltage umbrella or dissipation blanket ...... or both
Old 4th May 2014, 05:55 PM   #2438
Jason Hubbard is offline Jason Hubbard  United Kingdom
Jason Hubbard's Avatar
Default Finalising my Aleph-X, spkr protection and servo's
I'm just finalising my Aleph-X prototype before building my final form mono-blocks with wife acceptance factor included.
I have a few problems that seem to already have been discussed;
I need to drive my amplifiers from a single ended source and tried to use a single to balanced converter (based on DRV134) - all worked well until one day the DRV134 gave up and put one output at v+ rail level. Not a problem because I only had a load resistor connected across the speaker outputs but I would have cried my eyes out if I had popped a driver in my speakers - A speaker protection circuit would seem the obvious answer but I have some concerns about it tripping because it will be comparing DC from the speaker outputs to ground but the amplifier outputs are referenced to each other rather than to ground. The DC offset is also very temperature dependant (which brings me back to the servo circuit). Has anyone implemented speaker protection on an Aleph-x?
Is there a preferred method (i.e. KTY81/110 temperature sensor(s) vs a servo?)
Old 4th May 2014, 07:01 PM   #2439
Zen Mod's Avatar
you have somewhere on forum schmtc made by EUVL - spk protection for balanced amps
look for "XEN Balanced Speaker Protection Public 131003"
Old 4th May 2014, 07:05 PM   #2440
EUVL is offline EUVL  Europe
http://xen-audio.com/documents/f5x/X...c%20131003.pdf
There is an updated, improved version (JFET input) with a PCB layout.
But I have no time in the next 6 months to verify and publish.
So you should try this one first.
Patrick
xen-audio.com
Aleph-X builder's thread.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
