Aleph-X builder's thread.
Old 26th January 2011, 07:15 PM   #2091
Eric is offline Eric  United States
Eric's Avatar
Originally Posted by h_a View Post
The X-ed amps are usually rather sensitive to different DC-impedances at their inputs, so AC-coupling is a good measure. Even more so for balanced vs. unbalanced operation.
Hannes
Interesting... I would have thought Balanced would be less sensitive... Thanks for the tip!
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Old 27th January 2011, 02:13 AM   #2092
Eric's Avatar
William - that solved the problem! I moved the switch to the other side of the cap and it worked like a charm! Relative DC offset now holds constant at 0.0v as the amp warms up. Absolute DC offset behaves as before: it starts off somewhere near 9v from each speaker terminal to ground and reaches 2v within 10-15 mins, and hits 0v within 45-60mins and stays there.
Thanks again!
Eric
Old 2nd February 2011, 09:07 PM   #2093
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
Default Aleph X
Hi Gents ,
can someone tell me where to get the PCBs for this project please ?
many thanks , Rich
Old 2nd February 2011, 09:23 PM   #2094
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Rich,
I have a couple of the BrianGT rev 1 boards available. PM me if interested.
Peter Daniel just ran another batch of AJ-X boards. You could substitute ZVP3310s in his boards if you don't want to go with the jfet version. Just watch the pin outs - you will put the ZVPs in the opposite orientation as depicted on the silkscreen
Old 2nd February 2011, 10:02 PM   #2095
Default Thank you .
Hi Bob,
I would like to build 2 x Aleph 100 mono blocks . Which board would be the
best option ? Also , is there a BOM for either ?
Rich
Old 2nd February 2011, 10:52 PM   #2096
BobEllis's Avatar
The Version 1 boards are set up for 1 output device per quadrant (~30W out) with connections for additional off board devices. You could use the Burning amp single ended output boards or create your own. I'm sure there's a BOM or three somewhere in this thread.
Peter's X boards are set up for up to 3 output devices per quadrant. There are some suggested BOMs in the AJ-X thread.
Peter's are probably easier to use for 100W.
Old 3rd February 2011, 12:08 AM   #2097
Hi Bob,
thanks very much for the help .
Rich
Old 2nd March 2011, 04:36 PM   #2098
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default BOM
Link to the BOM please?
Old 2nd March 2011, 05:53 PM   #2099
Marra is offline Marra  United Kingdom
Rich I have several mosfet driver boards from the compact pcb group buy which you could daisy chain alongside Bobs version 1 boards if they are of any use to you. Each pcb holds 2 mosfets. Pm me if your interested.
Old 8th March 2011, 05:06 AM   #2100
surrealistix is offline surrealistix  India
Default Absolute DC Offset jumps up as I lower CCS current
I posted on the Alephx-x thead about the problems I am having with Absolute DC offset but didn't get a response.
I was wondering if I should have posted it in the builder thread instead.
Here is the link to the post on the Aleph-x thread.
http://www.diyaudio.com/forums/pass-...eph-x-320.html
I hope someone can help me sort this out.
Aleph-X builder's thread.Hide this!Advertise here!
